i want one of those...
Rufblackbird's Avatar
Location: formerly a grass shack in Hawaii, now Peoria, AZ
6 bolt vs. 4 bolt cv joints...is one better than the other?
Hey all,
I'm currently in the midst of swapping over aluminum trailing arms off a '76 onto my '72. The '76 uses a 6 bolt cv joint while the '72 uses a 4 bolt one. Is one better/stronger over the other?
Also, because my impact gun is pretty weak and I didn't notice the difference until I tore everything apart, instead of swapping the stub axles from the hubs could I swap in the 6 bolt output flanges from another 915 trans and just use the 6 bolt cv shafts from the '76? They seem a bit beefier as well (right one in pic). TIA!!
Jeff
'72 911 T Targa widebody VTK #111385 http://www.911vtk.com
Old 03-21-2005, 01:09 AM
Information Junky
island911's Avatar
Re: 6 bolt vs. 4 bolt cv joints...is one better than the other?
Originally posted by Rufblackbird
... could I swap in the 6 bolt output flanges from another 915 trans . . .
I would expect that they could be swapped. . . but I don't know for sure.
bump
Old 03-21-2005, 10:09 AM
thanks Glenn...anyone else?
Jeff
Old 03-21-2005, 07:28 PM
Early_S_Man's Avatar
Porsche Crest
Jeff,
You can't swap the '76 output flanges into your '72 915 ... the splines in the differentials are different!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 03-21-2005, 09:35 PM
Thanks Warren....I was looking through some records for the car today; trans in the '72 is from a '75, and the output flanges are from a '81 915. Would that work?
I think I'm gonna end up buying a better impact gun to swap the stub axles instead.
Jeff
Old 03-21-2005, 10:36 PM
