I just purchased a set of 8x9x16" Fuchs and I'm in the process of trying to find the right tire combination for them. I noticed the popular combo seems to be 225/50-16 front and 245/45-16 rear. I was about to run this combination, until someone posted a link to this tool:
http://www.wheelsmaster.com/rt_specs.jsp I've found that a combo of 225/55-16 for the fronts and 245/50-16 for the back yields a much much wider selection from tirerack.com (21 choices), and also brings the front and rear tire diameters within a 2mm spec of each other. Would I experience any adverse effects of running this tire combo in regards to ride quality, interference, scrub radius, or anything else I'm not thinking of?
- Everything's easier once you get started. - '95 993 C2 '73 911 Targa '88 BMW M3 '84 Mercedes 190e 2.3 16v |
Front would be too tall. 205/55/16 is normal, a 225/50 would fit better, and you've probably got to dial in some good camber/seriously roll your fenders not to rub.
'84 911, some sort of red color '05 Subaru WRX wagon |
I have a rubbing issue with 205/55s in the front on 7s. If you have your old tires, you can re-mount your 205s on your old 7 inchers while you decide what to do with the 8s.
btw I think the issue with respect to tire availability is the 9"x16" rears. Lots of choices on 205/55/16s, not much on 245/45/16s. I think 245/50/16s might look and drive like a truck tire. just my $.02 |
My car has turbo flares, would I still have these issues?
![]() I'm kinda bummed about the tire selection, at least there are some good choices, but no all-season tires available, only summer tires. I was also leaning towards the 225/55 - 16 fronts and 245/50 - 16 rears because if I go for the 225/50-16 front 245/45-16 rear, the rears will be about a 1/4" shorter than the fronts, which just seems odd to me.
Jon,
you are in good company being bummed out about the tire selection. I think you should talk to the tirerack people about the tire sidewall ratios you are contemplating. If you have turbo flares, then you can go wider for sure, but I will remain silent since I have no direct experience on this. I also noticed that you are in the bay area, calif. I really don't think you need an all season (read snow) tire. I have Bridgestone RE750s and before that had S-03s and S-02s. Only the Dunlops and Yokohama AVS Intermediates in my experience made a poor choice in the winter. The Brigestones are ok for everything except snow. And if it's snowing, I ain't gonna drive the Porsche anyway..... |
If I were you I would be thinking 225/45 and 245/45.
I just don't understand this availability issue, it's croping up in all sizes 15 - 19. I suspect that the tires folks just don't make enough profit on the rarer sizes.
i run 225/50 and 245/50 on turbo flares. Oz wheels so i cant comment on rimsize or offset but its lowered and works nicely
82 SC , 72 914 |
The issue w/ 245/50 vs 245/45 rears is that the additional height of the rears kills acceleration through the gears. Now if you are trying to maximize time in a particular gear for a particular track that may be useful, but for most, not.
225 in the front rubs... tried it
- Sean '87 Carrera |
All cars are different, idiosyncratic setup is also an issue.
225/45 vs 225/50 gives you a lot of breathing room. Not so necessary w/ 930 fenders but still nice to have.
according to the miata tire size calculator the 45 is a half inch smaller and the 50 is a half inch bigger than the stock size. Thats stock for my 82 sc anyway. I went from 45s to 50,s and saw no major difference
82 SC , 72 914 |
here's something I did when I was loking a some different 17s PHP Code:
If you have A/c I would be worried about the offset of the rears to avoid rubbing against the A/c tubes taht are in the wheel well.
Life is not a journey to the grave with a pretty and well preserved body but to skid in sideways, used and worn out saying " What a trip! |
Rusnak: It's not so much the width I'm worried about as it seems everybody and their mother goes with at least 9" wheels on the back, and it's been shown time and again 8" will work in the front with the turbo flares, it's the height I was worried about. I will contact tirerack as you suggest and see what information I can squeeze from them. Also, I went to my local wheel shop and he confirmed what you say about the season tires. He suggests I run summer tires as some of the all season tires develop "cupping" over time. He said you almost can't go wrong with tires nowadays, they're all pretty good.
Bill: Interesting note about that 225/45 / 245/45 setup you recommend, I haven't heard of that before. Porsche930Dude: Are those pics on your myspace page with that same tire setup? Doesn't look bad at all ![]() Richard Burns: I do have A/C, but I'm sure I'll be running at least a 1" spacer in the rear, and possibly a 1/2" spacer in the front, I'll wait till the tires are mounted to see what it looks like. . . . If you guys haven't yet, you should check out that tire size calculator (probably similar to that miata one) in this link: http://www.wheelsmaster.com/rt_specs.jsp It's pretty sweet!
Those pics are with the 45s the 50s were about an inch bigger overall which actually looks even better
82 SC , 72 914 |
Porsche930Dude, can you take a pic or two when you get a chance?
MBruns for President
I run 225/45/16 and 245/45 16
the 45 to 50 really makes a big difference
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
The new 50s are actually skinnier than the old 45s so there a bit more bulgey on the sidewall. First pic is the 45s dunlops and second is the 50s bfg. But its like bill said all manufacturers have there different specs
82 SC , 72 914 |
