-   -   Do I need my brake backing plates? (http://forums.pelicanparts.com/porsche-911-technical-forum/212323-do-i-need-my-brake-backing-plates.html)
porschenut 03-22-2005 10:13 AM
I just had new rotors installed and the shop removed the backing plates, saying it will help with cooling. I don't mind, as long as there's no good reason to leave them on. What purpose are they supposed to serve?
Wil Ferch 03-22-2005 10:57 AM
Carefull..."backing plates" are usually meant to be the stick-on thingies that are on the backside of brake pads...or they imply the metal "non-pad" portion thereof, too....
I think you mean the rock guards that cover the inside surface of the disc brakes. They can usually go unless you drive on gravel all the time. Look how sparse the design has become with the 986/996 cars...a mere square or triangle of a piece.....
Wil
porschenut 03-22-2005 07:03 PM
Thanks Wil. The Bentley manual calls them backing plates. Or maybe it was back plates, or something like that. I'll look again. I assumed they were meant to be dust shields and not really required.
strokher racing 03-22-2005 07:06 PM
Dave, they are called backing plates. Most track cars do not run them. You will be fine
Eric Hood
Wil Ferch 03-23-2005 09:06 AM
When I hear "backing plates" I think of the metal plate that the disc pad *material* is bonded too....part of the brake *pad*
Like here--->
http://www.supercircle.com/prod09.htm
Wil
PS- with this defintion , I can at least understand what "backing" means...as in a "backing" to the pad material. In the other definition for a dust/rock shield...what is the significance of the word "backing" ??
dhoward 03-23-2005 09:15 AM
Possibly a holdover from drum brake days.
targa911S 03-23-2005 10:02 AM
A british book about a German car. Got a spanner under that bonnet?
Bill Verburg 03-23-2005 11:21 AM
backing plates
As in the tin plates missing here?
http://forums.pelicanparts.com/uploa...1111608899.jpg
For winter use or driving through standing water or muddy roads they are useful otherwise leave them off for better cooling.
Or do you mean antisqueal pads
http://forums.pelicanparts.com/uploa...1111609145.jpg
leave them off as well
Wil Ferch 03-23-2005 11:34 AM
I guess my point was that I call the host metal "plate" that the disc pad material is bonded onto...... a "backing plate". Makes sense in this context too, as to why it's called that.
Yeah...the sheet metal dust shields ( aka "tin plates") is where I think this whole thread started....the "dirt shields" or whatever that protects the inside surface of the brake disc....
Wil
Bill Verburg 03-23-2005 11:36 AM
Will your version of a backing plate cannot be left off, no way no how;)
porschenut 03-23-2005 11:46 AM
Bill, yes that's it. The big round dishes that mount to the hub and protect the inboard side of the brake rotors is what I'm speaking of. Bentley calls it a backing plate, but the Porsche parts catalog says "protective plate". At any rate, they're staying off. Thanks.
Wil Ferch 03-24-2005 01:23 PM
Glad we got through all that.... :)
By the way...for those that have recently done this....I presume the rears can be removed in situ...but the front requires taking the bearings off first...right? ( speaking of a ...say... 3.2 Carrera)?
Wil
Bill Verburg 03-24-2005 02:34 PM
Yes, the rears are C shaped the fronts are topologically, a donut w/ some extra holes
http://forums.pelicanparts.com/uploa...1111706989.jpg
correct again you need to take it down to this point
http://forums.pelicanparts.com/uploa...1111707047.jpg
klaucke 03-24-2005 04:13 PM
Bill officially has pictures for everything.
ROW911SC 11-24-2016 07:26 AM
What's the correct factory finish for the brake rotor backing plates on an SC? Thanks.
zedsn 11-24-2016 09:05 AM
Have had my front backing plates removed for years on my 944 turbo with no ill affects and I drive the car in the rain often as well and no loss in braking or warped rotors.
ROW911SC 11-24-2016 09:10 AM
Asking because I've sen them plated, but the new ones from Porsche appear satin black? Thanks and have a great Holiday.
Steve@Rennsport 11-24-2016 10:22 AM
Yellow zinc plating.
ROW911SC 11-24-2016 10:43 AM
Thanks!
JohnJL 11-24-2016 10:55 AM
Wait...Bill probably has a pic for that too.
speedo 11-24-2016 11:23 AM
Even though this thread is 11 yrs old...
...you guys all missed the point.
Dave had a "shop" replace his rotors. A shop, really? Replace the rotors?
Fer cry'n out load! You backdate a carrera to a longhood yourself...but have a shop replace your rotors :eek:
I certainly hope that 11 years later you are not still having a shop replace your rotors!
Happy thanksgiving everybody. :D
Speedo
