Recreational User
Do I need my brake backing plates?
I just had new rotors installed and the shop removed the backing plates, saying it will help with cooling. I don't mind, as long as there's no good reason to leave them on. What purpose are they supposed to serve?
Carefull..."backing plates" are usually meant to be the stick-on thingies that are on the backside of brake pads...or they imply the metal "non-pad" portion thereof, too....
I think you mean the rock guards that cover the inside surface of the disc brakes. They can usually go unless you drive on gravel all the time. Look how sparse the design has become with the 986/996 cars...a mere square or triangle of a piece..... Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Recreational User
Thanks Wil. The Bentley manual calls them backing plates. Or maybe it was back plates, or something like that. I'll look again. I assumed they were meant to be dust shields and not really required.
Dave, they are called backing plates. Most track cars do not run them. You will be fine
Eric Hood |
When I hear "backing plates" I think of the metal plate that the disc pad *material* is bonded too....part of the brake *pad*
Like here---> http://www.supercircle.com/prod09.htm Wil PS- with this defintion , I can at least understand what "backing" means...as in a "backing" to the pad material. In the other definition for a dust/rock shield...what is the significance of the word "backing" ??
Wil Ferch 85 Carrera ( gone, but not forgotten ) Last edited by Wil Ferch; 03-23-2005 at 10:08 AM.. |
Unoffended by naked girls
Possibly a holdover from drum brake days.
Dan 1969 911T (sold) 2008 FXDL www.labreaprecision.com www.concealedcarrymidwest.com |
Double Trouble
A british book about a German car. Got a spanner under that bonnet?
I used to be addicted to the hokey pokey..........but I turned myself around.. 75 914 1.8 2010 Cayenne base |
![]() For winter use or driving through standing water or muddy roads they are useful otherwise leave them off for better cooling. Or do you mean antisqueal pads leave them off as well
Bill Verburg '76 Carrera 3.6RS(nee C3/hotrod), '95 993RS/CS(clone) | Pelican Home |Rennlist Wheels |Rennlist Brakes | Last edited by Bill Verburg; 03-23-2005 at 12:59 PM.. |
I guess my point was that I call the host metal "plate" that the disc pad material is bonded onto...... a "backing plate". Makes sense in this context too, as to why it's called that.
Yeah...the sheet metal dust shields ( aka "tin plates") is where I think this whole thread started....the "dirt shields" or whatever that protects the inside surface of the brake disc.... Wil
Will your version of a backing plate cannot be left off, no way no how
Recreational User
Bill, yes that's it. The big round dishes that mount to the hub and protect the inboard side of the brake rotors is what I'm speaking of. Bentley calls it a backing plate, but the Porsche parts catalog says "protective plate". At any rate, they're staying off. Thanks.
Glad we got through all that....
![]() By the way...for those that have recently done this....I presume the rears can be removed in situ...but the front requires taking the bearings off first...right? ( speaking of a ...say... 3.2 Carrera)? Wil
Bill officially has pictures for everything.
What's the correct factory finish for the brake rotor backing plates on an SC? Thanks.
Have had my front backing plates removed for years on my 944 turbo with no ill affects and I drive the car in the rain often as well and no loss in braking or warped rotors.
Asking because I've sen them plated, but the new ones from Porsche appear satin black? Thanks and have a great Holiday.
Yellow zinc plating.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Thanks!
Wer bremst verliert
Wait...Bill probably has a pic for that too.
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
