Can't get the shift console off far enough to work on shifter !
Searched forum, only came up with tips on finding/removing screws. Been there, done that ! My problem is the console is being held by the wire harness' to the A/C controls in the console. How do I get this thing out, short of taking the sawzall to the wires??? Thanks, Ted |
You might have to pull up carpet to get at one of the wire conections. The other wire conection is on backside of console. Mines an 85 so yours may be different. Good luck and take your time, you will get it.
Joe
Joe |
Ted - I have been working on the shifter in my 86 930 - I assume it is the same. You should be able to pull the housing up over the shifter and set it to the side without disconnecting the wiring. You may have to remove the shift knob to do this as it is a tight fit.
Bill |
Forget the sawzall.
1. Remove the back cover of the console 2. Remove all the screws you will now see on the side of the console holding down the little panel where the AC switches are mounted to 3. Remove the switches retainer at the front, and now remove the switches 4. Push the switch assembly off from the console 5. Remove all the screws holding the console to the body (4 or 5 screws) Once you can wiggle the console, lift it out over the shift knob and leave the wiring panel behind.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Thanks for the tips guys. It turned out to be a little more complex than expected
I'll post some pics in the next day or so to help out the next poor soul who trys this!! Found shift shaft ( say that 5 times fast) bushing disintegrated, ball cup worn, so at least it wasn't a futile effort ! Ted |
