-   -   Where can I get a replacement O2 sensor (http://forums.pelicanparts.com/porsche-911-technical-forum/212566-where-can-i-get-replacement-o2-sensor.html)
KatoKato 03-23-2005 01:12 PM
Hi there,
I'd like to purchase a replacement O2 sensor for my 3.2L.
Bosch Canada apparently does not have any universal sensors in stock (part#15735).
Does anyone know where in the US I could order a universal from?
Thanks,
kevjandon 03-23-2005 01:24 PM
Our host.
kqw 03-23-2005 01:24 PM
Why not get the right one and order it from Pelican?
KatoKato 03-23-2005 02:13 PM
Yeah ... that makes sense. The last time I looked (many months ago) I couldn't find the correct page. I kept on getting the K & N oxygen sensors when searching. I think I have it now at this link:
http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_exhaus_pg8.htm#item31
One question though regarding Part N-606-126-01. Is it and OEM or universal?
While I'm at it should I buy the removal tool? I assume that it doubles as an installer? Or can I just use a socket, or wrench to install?
Thanks,
kqw 03-23-2005 02:26 PM
For the price they charge, I have to assume that they are Bosch original's from pelican. You may want to check....
On the tool? First I would see if I could borrow one first because the frequency of use is about once every 3 years or so depending on your driving.
The torque on the sensor is 40 ft/lbs.
scottb 03-23-2005 02:42 PM
I bought the correct size socket from AutoZone, and cut a slot in the side with my Dremel tool. I think the socket was about $5, and it took about 20 minutes to cut the slot. Worked great.
At $200+ for my car, I have to assume that that's the OEM version, with the connector. The generic one (that I installed) is far less expensive, but it required that you graft the connector from the old sensor to the new one.
KatoKato 03-23-2005 02:55 PM
Originally posted by scottb
...The generic one (that I installed) is far less expensive, but it required that you graft the connector from the old sensor to the new one.
Grafting the connector is the soldering of three wires and shrink tubing? (As you stated in the other thread I started)
scottb 03-23-2005 02:59 PM
It's VERY simple if you have any soldering skills whatsoever. The black wire from the sensor gets connected to the black wire on the plug, and the two white wires on the sensor go to the white wires on the plug. Cover each solder joint with heat shrink tubing, and then use larger heat shrink to cover all of the joints. Don't forget to slide the unshrunk tubing on before you solder. BTDT.
It's less than a one-beer job, and it saves a great deal of money.
KatoKato 03-23-2005 05:10 PM
It's VERY simple if you have any soldering skills whatsoever...BTDT....
I think I can handle that. Thanks for the info.
Kato.
P.S. BTDT stands for?
scottb 03-23-2005 05:15 PM
BTDT = Been There, Done That (as in, I soldered wires together but forgot to slide the heat shrink tubing on first! :mad: )
kqw 03-23-2005 06:27 PM
Scottb...you are correct re: $200.00+ for 02 sensors for the years of '84 and '85.
I believe we are talking an '86 and that OEM sensor is about $100.00 or half the price....
Just for S&G's, in general, what are prices for generic sensors for an '86
scottb 03-23-2005 06:38 PM
About $50 +/-. Still a lot less than the OEM.
kqw 03-23-2005 06:40 PM
Thanks.....
KatoKato 03-24-2005 03:08 PM
I bought the correct size socket from AutoZone, and cut a slot in the side with my Dremel tool...
Scott,
What size socket is it?
Can you post a pic of the modified socket?
Thanks,
KatoKato 03-24-2005 03:13 PM
....The torque on the sensor is 40 ft/lbs.
That's tight. I installed a strut brace this winter and the shock tower bolts were put on at the recommended 32 ft-lbs.
turn6 03-24-2005 03:50 PM
http://oxygensensors.com/
$45.90
KatoKato 03-24-2005 04:46 PM
$45.90
I checked it out. The brand is "Walker". When it comes to oxy sensors how important is the brand name? (i.e. is the Bosch universal the same?)
Thanks,
KatoKato 03-24-2005 04:48 PM
...cut a slot in the side with my Dremel tool...
Is this what you're referring to?
http://forums.pelicanparts.com/uploa...1111715273.jpg
greglepore 03-24-2005 06:10 PM
There is a Bosch "generic" sensor, but if you do a search, there is a Bosch sensor that is a Ford replacement that is exactly the same, other than the connector. Cut and splice the wires. There's actually a pretty amusing thread buried somewhere where Wil and someone debate whether its ok to splice the wire.
Don't worry about it-splice the sucker.
scottb 03-25-2005 12:08 AM
Originally posted by greglepore
There is a Bosch "generic" sensor, but if you do a search, there is a Bosch sensor that is a Ford replacement that is exactly the same, other than the connector. Cut and splice the wires. There's actually a pretty amusing thread buried somewhere where Wil and someone debate whether its ok to splice the wire. Don't worry about it-splice the sucker.
Is the Ford sensor, with the connector, cheaper than the generic Bosch unit, sans connector?
Kato: That socket looks like what I made, though mine's cruder. Same concept, though.
KatoKato 03-25-2005 02:36 AM
....There's actually a pretty amusing thread buried somewhere where Wil and someone debate whether its ok to splice the wire....
Indeed there are! About three different threads.
Very amusing ....
KatoKato 03-25-2005 02:37 AM
The Bosch seems to be $5 more.
greglepore 03-25-2005 04:31 AM
Yeah, for some reason the generic is a couple dollars more, plus your local autoparts palace is likely to have the Ford for sure.
Wil Ferch 03-25-2005 04:42 AM
Yeash....that was me trying in vain to have a meaningful ( and "understandable") dialogue with a Bosch Engineer who used to frequent this board.
We really got nowhere when he *insisted* that the reference O2 signal was via the air path through the insulated wires...implying of course...that if you splice/solder the connections...that air resupply path would be interrrupted and corrupted.
I tried to give him the benefit of doubt and ( curious that I am for *truth*) kept egging him on for more details....supported by some sort of FACT that I can understand.....
Didn't work....he left in a huff .....
- Wil
KatoKato 03-25-2005 05:04 AM
Sorry Wil, no disrespect intended there at all. You (and most others on the board) know alot more about cars than I do.
It just sounds strange that the reference oxygen signal occurs via the insulated wires. Perhaps that's true in the OEM engineered versions of the O2 sensor.
It seems to me that the Bosch engineers would consider this when offering a universal setup where cutting/soldering/and shrink tubing is explicity in their instructions.
Or something like that.
jabb 03-25-2005 05:18 AM
Anyone know the Part Number for the Ford Sensor ?
Or what year and Model Ford ?
kqw 03-25-2005 05:24 AM
So what I infer from this is that: Generic vs. OEM....
Because it's labeled "OEM" then it commands a significant markup rather than being specifically engineered for the Porsche....
Hey Wil...
I gotta believe that there was something lost in the translation/conversation with that Bosch engineer...Air through the insulation??? I wonder if he completely understood the issue...Doesn't make sense...
Wil Ferch 03-25-2005 06:09 AM
kqw:
If you find the thread you will see there was NO misunderstanding.....both he and I were very clear, but he didn't follow up with any form of convincing argument why/how what is says can possibly be true. He asserts that the reference "air" signal under the wire insualtion needs an unimpeded path righ back to the DME unit.
I then countered with.."What about the connector in the engine compartment?. The wire "ends" there and another wire ( to the mating connector) runs back to the DME...."
See ? No confusion. But he never explained hinself fully.
That aside..if you find the thread...you'll see all kinds of Ford and Generic parts numbers...that are still valid as best as I can tell...
Wil
kqw 03-25-2005 06:24 AM
Wil, as always, I'll take your word for it...
Wil Ferch 03-25-2005 06:31 AM
Never take my ( or any other's) "word"....
Best to judge for yourself after reading this.....
http://forums.pelicanparts.com/showthread.php?s=&threadid=78442&perpage=20&highli ght=oxygen%20sensor%20bosch&pagenumber=1
- Wil
PS-- no offense taken on any of this. Sometimes "mining" for the truth leads you down a rough path...that's all :)
scottb 03-25-2005 01:00 PM
That's one of the beauties of this board...people disagree with each other all the time, but 99% of it (with the possible exception of certain people with strong opinions on chips) is in the spirit of getting information out to people so they can make informed decisions on their needs.
Wil, I never bought into the "air thru the wire" scenario in the old thread, but I found it interesting and give you credit for pushing the Bosch rep to support his contentions.
Sonic dB 03-25-2005 07:42 PM
I put a Walker generic sensor in my 86 two years ago...works great with no problems. Mixture is fine.
Bello 03-26-2005 09:59 AM
I check out oxygensensors.com
they have nothing on 88' 911 which one would work for me?
KatoKato 03-26-2005 04:27 PM
As far as I can tell the generic three wire can be used on 911's between the years of 1984 - 1994?
Please someone confirm this.
KatoKato 03-26-2005 04:28 PM
I would also try again as I get the same page as for 86 or 87 ...
JasonAndreas 03-27-2005 10:33 PM
Not always, well not at least for the 964 and 993 (i have no idea if it applies to the 3.2). The genuine Porsche O2 sensor is plunge-proof and the OEM Bosch units aren't.
scottb 03-27-2005 10:40 PM
what is "plunge-proof"?
Wil Ferch 03-28-2005 06:28 AM
Based upon my nerve-wracking dialogue with the Bosch Rep ( re: the "other" posts on this...) ...I don't think this assertiion is correct. The Bosch units ( either generic or made-for-Porsche) should be water tight and the replenished reference "air" ( if such is the case)...does not come from an open port to the atmosphere....rendering it "plunge-proof".
If you dig into the dialogue...you'll find that NTK... or others... might indeed fit...but may also have this "open" port that needs very deliberate splash shielding.
- Wil
DW SD 03-28-2005 07:41 AM
Not wanting to wait for shipping and looking for instant gratification, I just bought and installed the Bosch unit 13593, which has 16" leads. Everything is great! Interestingly one parts store recognized the part #: 0258003953 While the other recognized 13953 as the correct number. The O2 sensor was $42 (autozone & Kragen). total time to solder the leads, cover with shrink wrap and install the unit, about 1 hour.
Doug
RickM 03-28-2005 07:48 AM
FWIU the proper "generic", Bosch sensor is the same sensor as OE less the specific harness plug. The generic sensors come with a well designed solderless splicing kit which you use with your own plug. I used it on four sensors for a '97 Twin Turbo and it worked perfectly.
The generic part numbers are available at the Bosch site via their part finer.
