Dead Battery
What could be drawing power? I have had no troubles in the past and all of the sudden my battery went dead in just a couple of days. This past winter it would sit for 3-4 weeks at a time with no problems. I did hose off the motor last weekend, could I have hit somethiing that caused a power draw? Dome off, lights off, only the clock rolling. Thanks for any advise!
Kris
1986 Targa 1993 Corrado VR6 2005 325xi 2010 135i 2011 X5d |
First things you need are a multimeter, to find out where the draw, or ground, is, and a hygrometer to find out if your battery cells are okay. If you don't have those, you're simply playing a guessing game.
Stephan
Stephan Wilkinson '83 911SC Gold-Plated Porsche '04 replacement Boxster |
Pull all the fuses and see if it still loses charge
1984 3.2 Carrera Impact Bumpers on track: http://www.youtube.com/watch?v=C4qbFNkdD2o |
You do not have permissi
Pull the negative battery connector and put an ampmeter inline. Then pull fuses individually.
Check battery, lead-acids can only be fully discharged a few times. Use search function.
Meanwhile other things are still happening. |
With the ammeter in series it shoul read <60 ma .
Joe |
For an '86 it should be closer to 16 mA......
Report back if your power windows "function" when the car is "off" and the door is open..... A search will show you why..... Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Blockchain Tech Inventor
A Mean Green Lifted 1972 C10 Long live the king! |
More specifically...
It was sticking allowing the P/W relay to be "Always" energized.....therefore running the battery down. It's where I'd look first after a fuse/draw check. Wil
You know what it ended up being is the trunk light switch. While it is up I depress the plunger and the light doesn't go off. Then I close it as much as possible and it doesn't go off. I tried sticking my wife in to watch but she's just not quite small enough. Anyways, I had the battery tested and it's toast, over 5 years old.
Thanks for reply's as normal!
kslizzy,
Are you still married. If so does she have any single sisters? KevinS
1971 Porsche 911 T Targa |
