What’s the use
The Giants have won the Pennant!, the Giants have won the Pennant!! the Giants have Won the Pennant…!!!! It lives !! It lives!!, It starts,( it starts good!), …..the Giants have won the Pennant!, I did it!, I did it!, we did it!, dizzy out dizzy in, 3:15, 3:15, 0.1. 0.1, 162435, …… my 911E is going on the road again!SmileWavy SmileWavy :D :D :D
Thanks to Pelican Parts Thanks to the members of Pelican 911 Technical and Rebuild forums Special thanks to experts:, 911mot, addictionMS, JoeAksa, Eagledriver, ChrisBennet, John Walker, cstreit, Kurt V , Snowman, aigel, AFJuvat, dtw, 911cars, Henry Schmidt, , Grady Clay, Wayne, , RoninLB, DarrylD, lateapex911, john_cramer, jstobo , many others !! :D :D :D |
Good news. So what was the problem?
Tom |
However! I took out the dizzy and then put it back in again, but unlike the first time, watched for the rotor rotation to hit right at the number one wire at TDC. (last time all I did was intstall it not looking for any meaningful rotation, so I think it may have been in the vicinity of no.1 but not close enough, only close enough to fire only one cylinder) Last, I redid the valve adjustments. The engine is amazing. Really "winds up", and it does not leak! |
Congrats. Follow all the break-in procedures to ensure a long smoke-free life. Glad it turned out to be something non-invasive and non-costly.
I broke in rings and then new cams w/ 30w non-detergent.
Now if only the Giants could really win the pennant...
congrats, feels goos doesn't it,
jim |
Then things cleared nicely, and followed the advice and changed the oil. I used 10W-30 Castrol GTX on this first one. Did not see any metal parts in the oil or on the magnets. .......another thing :D :D no smell of gas in the oil! (as before the rebuild). .......AT first I thought the engine was missing on one cylinder, until I realized I had the screws tuned in and was too lean. Put them out half turn, and all fired smoothly. I'm trying to find best idle next, and then get the coupler just right before going out of the driveway. Thanks (Besides Pelican (where I ordered intermediate shaft bearings,) I also want to thank Stoddards and EBS). |
I bet a lot of you guys didn't think he'd ever make it. Some even called him a troll. Well, trolls don't end the sham by saying they were sucessful and thanks to all that helped.
I, for one, congratulate the guy more for not running away from the BBS after being called a few things unkind than for his success in getting the motor to run. HGP, whereever you are, have a ball in your car. You deserve it. |
Day #2 breakin.....OUT on the road!!
Doin the Wayne thing for the breakin. Out on the road, varied RPM, tried to stay away from idle. (had too anyway) 1. Engine, (compared to before rebuild), sounds like a small jet plane at the above 2000 RPMs. 2. I'm really pleased.......but...... haven't found correct idle. a. car will stall at a stop. b. sounds like it's missing at idle (but not at higher RPMS, At higher RPMs it’s definitely hitting on all six) 3. But the idle mixture screws I have about 1/2 turn below Haynes, because I want no gas in the oil. 4. Did the smell test after today's drive, and no smell of gas in the oil! So I guess I will go ahead and turn the carb screws out some more and hopefully will smooth the idle. 5. All in all, I'm :D :D :D |
Great! Now that you're in top spirits, you'll see fit to tell your name and where you live.
Kirk,
Glad to see that its finally running. NOW the fine tuning and break-in begins! When you have a problem like this, its always best to go back to square one and confirm everything. Now that its running and you have learned keep moving forwards. The 911 is not that difficult of a car to work with. JoeA |
Excellent! Congratulations!
Enjoy your car. |
| All times are GMT -8. The time now is 01:20 PM. |
