Wider is Better
wholberg's Avatar
Old wires--replace??
My car ('87 Carrera) runs great and idles smoothly. At night I see no arcing around the plug wires, but the exterior insulation is so brittle I can peel pieces off with my fingernails. The car is new to me so I do not know how long the wires have been in there.
Am I looking at an ignition failure waiting to happen? My inclination is to replace them, but I guess I just want reassurance that I am not breaking the "if it ain't broke, don't fix it" maxim.
Wider is Better
Old 04-01-2005, 05:54 AM
If it were mine, I'd definately replace them.
Jerry M
'78 SC
Old 04-01-2005, 06:10 AM
I would replace them, and the plugs, cap, rotor, oil change, tranny fluid, gas filter, air filter, and any other hoses that are suspect on the car.
Now you know what you have.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 04-01-2005, 07:07 AM
Wider is Better
wholberg's Avatar
Hijacking my own thread
OK, I will replace the wires so I know what I have. When I purchased this car, I took it to a Porsche shop and they adjusted the valves, changed oil, cap, rotor, air filter, flushed brakes.
I will replace the old wires, plugs, fuel filter, and check hoses.
Is there anything else I should do so I "know what I have"?
Repack/replace wheel bearings? Anything else?
Non-critical repairs it needs:
Drivers door does not lock (yes, I've done a search)
Buzzer does not work when lights are left on
Gas gauge sticks sometimes (sending unit, I presume)
The car has 88,000 miles and averaged about 1500 miles/year for the last 10 years (according to Carfax).
All suggestions/ideas are welcome.
Wider is Better
Old 04-01-2005, 07:58 AM
Re: Hijacking my own thread
[i]
That is a real good start. Check to see if your oil lines are leaking, if so, change them. Your oil breather lines are real prone to leaking too. The gas return line on the 3.2L engine seems to get old and crack a lot. Don't forget transmission gear oil. I don't care much for the blue stuff, but Valvoline synthetic does well for me. Redline also good, in my BMW.
Wheel bearings should not have to be repacked unless you feel a little radial play at the rotors.
It's inside the door, time to tear into it.
Ah, just ignore it, thank god it does not buzz.
Quote: Gas gauge sticks sometimes (sending unit, I presume)
Don't know, this is not a real common problem.
[/B]
Old 04-01-2005, 08:40 AM
