KCPSG's Avatar
speedometer off
yesterday I took a long drive and took along a friends GPS to compare my speedometer to, and found that I was 5mph off @ slower than 50 mph but was off close to 10 mph at all speeds of 60 or greater.
I remember someone doing a writeup on here about how to drill a hole in the speedo and make the adjustment...but my question is. will this adjustment fix the total problem or are my speeds still going to be off @ some range? AM I better off sending it to North Hollywood Speedometer or palo alto speedometer or some such place to fix this.
Phil
2005 GT3 Milltek Exhaust/ECU reflashed/OEM Short shift
1988 911 coupe (GP white) Turbocharged
1998 BMW 328i
Old 03-26-2005, 04:55 AM
Most 911 speedo's are off by that amount. So are their odo's. It is possible to do yourself but if you can part with the $100 I think it is better to send out. I sent mine to No. Hollywood and it came back with a new face and very accurate. The odo will always be wrong even after calibration.
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 03-26-2005, 05:54 AM
KCPSG's Avatar
Thanks Dean do you know if its accurate all throught the speed ranges...Like I said I have a 5mph diff @ lower speeds and a 10mph @ higher speeds..
Phil
1998 BMW 328i
Old 03-26-2005, 04:47 PM
Mine came out pretty accurate. At 35 it is right on and also at 60. I like to do everything I can myself on cars. But some things are not worth doing yourself. I even researched how to calib it myself and said eff it.
Dean
Old 03-26-2005, 06:23 PM
I did the drill and pot reset as in the archives dialed into my specific tires. Different tire mfg will have different diameters for the same tire size afaik. The odo is still the same. The routine is 30mph and 60mph testing. Mine's perfect, afaik, when compared to following a new Accord on a flat straight road in cruise control.
that said gauge faces get kinda worn out w/age so Dean's advise is best.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-26-2005, 06:59 PM
