Me like track days
Craig 930 RS's Avatar
Question COSTCO & nitrogen for tires
Does anyone know if Costco will fill tires with their nitrogen if not purchased at Costco?
I want the benefits of reduced air pressure changes when hot vs. cold. I have the air bleeders on the wheels of my 930, but I currently have to add air when the tire returns to cold after the bleeds off when running hot.
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 06-29-2005, 04:52 PM
Randy Blaylock's Avatar
Nitrogen doesn't really help with pressure creep in any tire that has been mounted using any quantity of tire spooge, as is typical with almost all short aspect ratio radial tires nowadays. The moisture in the spooge on the inside of the vessel (the mounted tire) will negate the benefits of using nitrogen. The total temperature change isn't nearly in the same range of course, but when water converts to steam it expands 1700+ times in volume. So you can see where the moisture content is a large component of the creep.
Nitrogen is not the holy grail anyway, it just helps. Even when mounting my stock car tires dry, they still experience pressure creep, just not as much. They build from 16 psi to 30 over a run, rather than having to start at 8 psi.
Not to mention the first time you top off the pressure after the tires cool off, you will be diluting the nitrogen that you initially used. The primary benefit of using nitrogen is the transportability of large volumes of compressed air in a relatively small vessel.
The alternative is to carry a full 10 gallon tank of ordinary compressed air that should last you a full track day. I'd just get used to using it, or discontinue using the tire reliefs and put up the varying handling characteristics as the tire pressures grow from the low side of ideal to the balloon side. Not to mention cutting your tire life in half.
Old 06-29-2005, 05:11 PM
Me like track days
I was told that nitrogen virtually eliminates tire pressure increases - since it apparently does not, then I won't even bother with nitrogen.
Old 06-29-2005, 05:23 PM
Detached Member
Hugh R's Avatar
Normal air is 79% nitrogen, 20.8% oxygen and the rest argon and other stuff. Why does Costco put in nitrogen, I never knew that.
Hugh
Old 06-29-2005, 06:32 PM
The reason nitrogen is put into tires (AIRCRAFT) is that it does not support combustion and I had belived that presure changes were smaller between the extreme temperature changes from 164'c ( at 165'c the fuse plugs blow and deflate the tires) to -65' c at 35,000'.
its possible racing cars use nitrogen for those reasons but i never knew COSTCO used it.
1983 911SC
1977 911S "parting out"
Old 06-29-2005, 07:54 PM
Administrator
Jack Olsen's Avatar
Does Costco sell nitrogen in tanks?
Old 06-29-2005, 10:23 PM
Registered Cruiser
jorian's Avatar
Chinch bugs....
87' Carmine Red Carrera - Keeper
82' Silver SC - Sold 79' Gran Prix White SC - Sold
05' Black C2S - Daily driver
I have never really completely understood anything.
Old 06-29-2005, 10:46 PM
Do a search on the Ideal Gas Laws and you'll see that if you double the temperature, you'll double the pressure, regardless of gas. The advantage to nitrogen in higher levels of racing is the 'elimination' of water. If there is water (liquid or vapour) in the tire, the pressure will end up being more than the Ideal Gas Law would indicate. However it is a pretty small difference and probably not worth the cost/effort.
Matt B
'73 911E
Old 06-30-2005, 01:03 AM
Paul Valcourt's Avatar
The main use of nitrogen in tires is to reduce leakage and condensation. Nitrogen molecules are larger.
75 targa 2.7
Lean and green
Old 06-30-2005, 12:01 PM
Me like track days
Bottom line - Don't waste your money going out of the way to get Nitrogen. Unless you have a steady supply for refill -
Old 06-30-2005, 12:04 PM
304065's Avatar
. . . manganese. . . . you know, credit troubles. . .
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 06-30-2005, 12:07 PM
Detached Member
Hugh R's Avatar
If that were true, then after a while, the only gas in the tire would be nitrogen, if the oxygen molecule were smaller.
Hugh
Me like track days
Theoretically yes, practically - probably not
Old 06-30-2005, 12:09 PM
pwd72s's Avatar
I've been running my cars with a nitrogen blend for decades. My dad & gramps did the same...
Old 06-30-2005, 12:31 PM
Registered Cruiser
jorian's Avatar
I'm on a five year plan...
Old 06-30-2005, 01:00 PM
Slant930's Avatar
man, that is too funny!
Tim
1983 930 w/ goodies
Old 06-30-2005, 02:19 PM
Costco manager told me they do it because nitrogen filled tires hold pressure longer. It makes business sense for them because many people don't check air pressure they were getting a lot of warranty claims as a result.
Bill M
88 Carrera
86 944 SP1
06 Cayman SPC
Old 06-30-2005, 07:06 PM
Stranger on the Internet
patkeefe's Avatar
This is the first time I ever heard of someone using nitrogen in their tires. I must have lived a sheltered life. I've ever only used it for purging lines to take the flammables out, or aircraft Dewar tanks.
Live and learn.
Patrick E. Keefe
78 SC
Old 06-30-2005, 07:40 PM
brittbolen's Avatar
Nitrogen filled tires are used on long haul trucks regularly. The nitrogen is drier than air and this reduces the rate of oxidization to the inside of the tire. Thus the tires last longer and can be re-tread more times.
The Digital Chassis in Durham put N in my tires, he's got a handy little machine in the back that just filters it out of the air.
As has been mentioned Costco does it for safety, N leaks out slower so it improves safety for people who don't ever check their tire pressures.
Britt
Old 07-02-2005, 06:09 AM
