-   -   My $5.00 trunk carpet "kit" (or something close to that) (http://forums.pelicanparts.com/porsche-911-technical-forum/213754-my-5-00-trunk-carpet-kit-something-close.html)
H.G.P. 03-30-2005 04:35 PM
Since I rebuild the motor, I no longer needed my 3ft. X 5ft. Vehicle and Utility Mat (Dynomat product), I purchased at Autozone back when.
So I found another use, I've been needing. Weighs hardly nothing:
http://forums.pelicanparts.com/uploa...1112232770.jpg
http://forums.pelicanparts.com/uploa...1112232867.jpg
pwd72s 03-30-2005 04:38 PM
Not bad...going by the pic, I'd say it's pretty close to stock carpeting color!
H.G.P. 03-30-2005 04:48 PM
Hee, hee, :D :D , I'm calling it "charcoal"
autoxracer31 03-30-2005 05:43 PM
isnt that stuff also good sound deadening?
H.G.P. 03-30-2005 05:57 PM
The "Utility Mat" is a different material, I beleive the product your referring to is "rubber" like with a peal and stick and is also a different weight.
Cornpanzer 03-30-2005 06:30 PM
Now if you could find a product to remove the pesky bush from the front bumper.........
H.G.P. 03-30-2005 06:45 PM
I like that bush, keeps persons from walking through. the car is back inside the garage now though.
K. Roman 03-30-2005 07:10 PM
Good job! Looks good enough to pass my Concours test!:D
Joeaksa 03-30-2005 07:11 PM
And how is it running??? Hope no leaks and finally the idle is where it should be?
JoeA
H.G.P. 03-30-2005 08:09 PM
JoeA
Idle was perfect today. Ran strong. No leaks, (with the exception of 2-3 nuts on lower valve covers. Not concerned as new lower valve cover gaskets that will be replaced soon next oil change)
Also another description is it's running "clean", no smoking, no smoking at start up.
H.G.P. 03-30-2005 08:20 PM
One other note, I'm actually going through adjustment of learning to not see leaks! Before the rebuild, besides all the grease, there was always considerable leaking both sitting and after driving.
Now none! It's a real physical energy saver, and I'm really having fun, cleaning the car up, weather is improving finally. Timing for all this has also worked out well. (Too look under and see everything dry is almost a dream into 4 years of the opposite)
