H.G.P.'s Avatar
My $5.00 trunk carpet "kit" (or something close to that)
Since I rebuild the motor, I no longer needed my 3ft. X 5ft. Vehicle and Utility Mat (Dynomat product), I purchased at Autozone back when.
So I found another use, I've been needing. Weighs hardly nothing:
1969 911 E Coupe
"Little Bull" "Horse"
"H." Heart, "G." Gears, and "P" the Porsche
Old 03-30-2005, 04:35 PM
pwd72s's Avatar
Not bad...going by the pic, I'd say it's pretty close to stock carpeting color!
Old 03-30-2005, 04:38 PM
H.G.P.'s Avatar
Hee, hee, , I'm calling it "charcoal"
1969 911 E Coupe
Old 03-30-2005, 04:48 PM
autoxracer31's Avatar
Send a message via AIM to autoxracer31
isnt that stuff also good sound deadening?
Old 03-30-2005, 05:43 PM
H.G.P.'s Avatar
The "Utility Mat" is a different material, I beleive the product your referring to is "rubber" like with a peal and stick and is also a different weight.
1969 911 E Coupe
Old 03-30-2005, 05:57 PM
Cornpanzer's Avatar
Now if you could find a product to remove the pesky bush from the front bumper.........
Check out my blog for Parts & Cars For Sale - http://renn-spot.blogspot.com/
1970 911S,
10 sec 67 Beetle (300 rear wheel HP)
RGruppe#252
Old 03-30-2005, 06:30 PM
H.G.P.'s Avatar
I like that bush, keeps persons from walking through. the car is back inside the garage now though.
1969 911 E Coupe
Old 03-30-2005, 06:45 PM
I'm not here.
K. Roman's Avatar
Good job! Looks good enough to pass my Concours test!
"When do we say we can stop the Whole-Sale State-backed discrimination against straight white males? - island911 (This guy is insane, no?)
Old 03-30-2005, 07:10 PM
Senior Member
And how is it running??? Hope no leaks and finally the idle is where it should be?
JoeA
2013 Jag XF, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB
Old 03-30-2005, 07:11 PM
H.G.P.'s Avatar
JoeA
Idle was perfect today. Ran strong. No leaks, (with the exception of 2-3 nuts on lower valve covers. Not concerned as new lower valve cover gaskets that will be replaced soon next oil change)
Also another description is it's running "clean", no smoking, no smoking at start up.
1969 911 E Coupe
Old 03-30-2005, 08:09 PM
H.G.P.'s Avatar
One other note, I'm actually going through adjustment of learning to not see leaks! Before the rebuild, besides all the grease, there was always considerable leaking both sitting and after driving.
Now none! It's a real physical energy saver, and I'm really having fun, cleaning the car up, weather is improving finally. Timing for all this has also worked out well. (Too look under and see everything dry is almost a dream into 4 years of the opposite)
1969 911 E Coupe
Old 03-30-2005, 08:20 PM
