Paint stripper recommendation
Can anyone recommend a decent paint stripper? I just bought an old Carrera tail and lid and would like to strip it all before painting.
Also, where can I buy some POR-22 (rust treatment paint, not for the tail of course)?
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 04-01-2005, 06:47 AM
aircraft remover on the metal.
206 637 4071
Old 04-01-2005, 06:49 AM
Stressed Member
Scott Clarke's Avatar
Try your local hot rod shop for POR products.
-Scott
'70 911E short stroke 2.5 MFI. Sold
'56 Cliff May Prefab
Old 04-01-2005, 06:52 AM
you said paint ....stripper........
I was thinking finger paints.
Looking for 87-89 Silver Cab 911, black interior, must be low miles, near pristine, no accidents, well sorted.
Old 04-01-2005, 06:54 AM
oneblueyedog's Avatar
I stripped my front valence with Stipper from Home Depot. It was heavy duty stuff in a gallon container. Worked as well as the AC stripper aerosol. Don't use on FGlass.
78SC coupe, Silver Metallic
Old 04-01-2005, 06:56 AM
I second the aircraft paint remover for metal, then treat the metal before priming. Good luck!
Alex
Its easier asking dumb questions than fixing dumb mistakes
1974 Porsche 911 Coupe, RSR Project
1976 Porsche 911 Targa, Black
1986 Porsche 911 Carrera, Black
2006 Porsche Cayenne S, Black
Old 04-01-2005, 07:52 AM
scottb's Avatar
If you can't find Por-15 locally, you can buy it on their website. www.por15.com. I recently placed an order, and it showed up pretty quickly.
1984 Targa
Old 04-01-2005, 10:47 AM
Eric Coffey's Avatar
Re: Paint stripper recommendation
Use the standard "aircraft stripper" on the metal deck lid as mentioned. On the actual tail base (fiberglass/Fibron) use the "aircracft stripper" made for fiberglass. It is the one that comes with the spray bottle. Most all auto paint supply stores should carry both varieties.
Old 04-01-2005, 12:44 PM
I actually got a great deal on an OEM original Carrera tail made of Metal. So, safe for all stripper it is.
Old 04-01-2005, 01:03 PM
Ahh, yes. For some reason I thought you were referring to the `84-`89 OEM Carrera tail variety (which it is NOT metal). Good luck, and make sure to lay down a big sheet of cardboard or vinyl, because it will make a mess!
Also, to increase the stripper's effectiveness, brush it on then quickly lay cling-wrap or a trash bag over the area to be covered (to prevent the stripper from evaporating). That way you will minimize the number of "coats" needed.
Old 04-01-2005, 03:36 PM
