odd car quiz
You don't win anything, but who can tell me about this car that is a first cousin twice removed. (or something like that)
![]() It's been too long since we played this game, and I'm bored.
Kantry Member
Tatra, circa 1950??
Les
Best Les My train of thought has been replaced by a bumper car. |
Nice guess, but no, the age is about right.
I'd say it's a Denzel.
______________________________ Dave 1969 911T Coupe 1972 911E Targa |
Then you'd probably be right.
From http://vea.qc.ca/vea/marques1/denzel.htm
Here's some other info that I found on the net
Manufacturer: Denzel Class: F Model: 1300 Super ------------------------------------------------------------------------------ DESCRIPTION: 2-Seater Aluminum Roadster Dry Weight: 1320 lbs ------------------------------------------------------------------------------ ENGINE: Type .............. 4 cyl opposed, air-cooled, ohv Bore & stroke ..... 3.07" x 2.63" (78mm x 67mm) Capacity .......... 1289 cc (78.1 cu in) Comp ratio ........ 8.5:1 Head material ..... Aluminum Port size ......... Intake 1.25"; Exhaust 1.10" Piston material ... Aluminum Piston weight ..... 13 oz Timing data: Intake .... Open 15° BTDC, Close 55° ABDC Exhaust ... Open 55° BBDC, Close 15° ATDC Valve lift: ....... 9.32mm Valve head dia: Intake .... 1.41" Exhaust ... 1.25" Valve spring ...... Carburation ....... Two Solex 40 PH-4 ----------------------------------------------------------------------------- TRANSMISSION AND DRIVE TRAIN: Ratios: 1 3.6 2.83 2 1.88 1.81 3 1.23 1.25 4 0.815 0.875 5 Final drive ratios: 4.375=35/8 ------------------------------------------------------------------------------ CHASSIS Wheelbase ................... 82" Track dimension, front ...... 52" Track dimension, rear ....... 52" Shock absorber .............. Steering ratio .............. 14.15 Brakes ...................... Tire size ................... 5.60 X 15
Nice and light at 1320 lbs. Any idea of HP?
How about this one?
1974 911s "It smelled like German heaven" http://www.youtube.com/watch?v=6ySt9SeZl9s |
Isn't that the Le Mans 356 that was streamlined to improve it's aero for the long straights.
VW Type 60K/10...pre War streamliner designed for the Berlin-Rome run....
3 built....one was ruined by GI's as they over-ran Gmund. The pictured car was once owned by the one-armed Austrian driver...Otto Mathe. Pre-curser to the post war 356......Erwin Komenda body design. ...I guess.... ! Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Guess that one was too easy...
Another?
RSK
or more completely, Type 718 RSK/RS60
Another weird one.
Dauphin porsche?
89 Carrera 3.4 "There is a right way to go around a corner - it's called the line." -- PCA DE speaker bryteside.com - good things happen. |
Elva Porsche.....
he he.... Wil
Okay Will...
Looks like the Dusio-inspired Cisitalia GP car of 1948.... Supercharged 1.5 Liter V-12 and all-wheel drive...
..I would guess.... Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) Last edited by Wil Ferch; 03-29-2005 at 01:25 PM.. |
Ok Wil;
Here's one that will slow you down for half a beat.
John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman |
Ahhhh.....ummmm.....
wait a minute...... ahhh....hmmm..... Guogliout (sp?) design....right? - Wil Edit: the wheels....where I have I *seen* these wheels ???
