7's are a rubbing
I just moved my 7's to the front with 205/55/16 ES100's and the front left is rubbing on the bumper extension lip and about 6 inches above it.
![]() ![]() I drove the front left up on a couple of 2x6s and checked for clearance and the bumper extension rubbed so I rolled it and the rest of the wheel arch appeared to have plenty of clearance. This morning on a 70 mph right hand sweeper with a bump, Wham, It did not sound good. Now, its hitting about 6" above the bumper extension. Most of the issues I read about are along the top of the arch. Is this a common problem area? I need to do some more rolling or cutting. |
Never seen it rub there.......
Jeff
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
check the alignment.. caster might be too positive?
Harold
Yep - from the picture it looks like the entire wheel is too far forward in the wheel well. You can loosen the shock nut and move it back (by pushing the shock top forward) but this will of course change your alignment.
Bill |
Hmmm,
I will ckeck the caster and alignment before I do anymore rolling. Thanks Guys, Dave |
Yes, that location is going to be close on most late cars.
I didn't have the issue with 7s and 205/55x16 but did w/ 8s and 235/45x17 A few minutes w/ a grinder did the trick. I wouldn't change my alignment, especially if it was done right and recently.
Bill Verburg '76 Carrera 3.6RS(nee C3/hotrod), '95 993RS/CS(clone) | Pelican Home |Rennlist Wheels |Rennlist Brakes | Last edited by Bill Verburg; 04-03-2005 at 08:34 AM.. |
My 7's with Michelin Piolet sports are no where near that close to the front of the wheel well.
How much clearence do you have on the other side?
"Coffee is for Closers" "Push the button Max!!!" |
Bill,
My car has not been aligned in the 7 years I have owned it. The tires wear evenly and it drives well. New bilsteen sports two years ago. Next year I plan on upgrading t-bars and suspension. Dave |
the one universal seems to be drivers front is the worst
It looks to me like your bumper has been pushed back. It should be a smooth seam where the bumper and chin spoiler mate with the fender. If it is pushed back, you can probably bend it forward so that the assembly aligns with the fender well.
That being said, I agree the tire appears to be too far forward... but that could be a function of a misaligned bumper.
Ben Fegan 1988 Carrera Targa |
Don't know if it's any consolation, but my '86 has the same problem. I was able to roll the trim piece behind the bumper enough to just clear. No problem on the passenger side. One of the "joys" of owning a hand built car!
David Dryden '86 911 Coupe '05 BMW X5 4.4i |
Check right side and left side wheel base.....hope you don't find any surprises..but do report back what you find.
Yes..the front bumper and panel behind the bellows seem moved back a bit. Check. The odd thing is the visual of seeing the wheel not centered in the wheel well. I'd drive to find out what that's all about. Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
In the pictures the wheels are turned a little to the right.
I went out and got the wheels strait and the wheelbase measures with in a 1/16". This is good? Measuring from the plate at front of rockers to the rear of front tires is close to 3" on both sides. I could not see a difference. The clearance where my finger is in pic is .75" on L and 1.25" on R. Hmmmmm, The bumper extension is back about 1/16" but so is the right. I had never noticed it before. The left is hitting just above the bumper. |
MBruns for President
Sure your car hasn't been whacked?
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
No one has mentioned right height. Looks kinda low. Fegan and Ferch have noticed the misallignment of the bumper ass'y. That seems to be the biggest part of the problem. Having rubbing issues of my own recently, I know the sound you are refering to and it's rather disconcerting, to say the least. |
It is lowered. Ground to front fender lip is 25".
Dave |
Somatic Negative Optimist
Dave: I have 7's with 205/55-16's in front and 25" to ground without any problems at all. My camber is about 1/2 deg. It could be that the bumper was pushed back at one time or the left fender was worked on/replaced/repaired? Check the top of the strut where the 3 Allen screws are and see if there is room in the big hole to gain some clearance there. Compare the position of the left strut-top to the right one. Are they both equal?
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
I took the wheel off and the suspension looks fine and there is no evidence of damage. So, I moved the bumber extension foward to correct the alignment with the wheel arch and following the advice of Bill Verburg cut away the lip. I left about 3/16", filed it smooth and painted the edge. This morning I drove the same 70 mph right sweeper and no evil sounds. Rubbing is gone. Now I can enjoy the 7/9 upgrade The ES100's are impressive. Only a couple of hundred miles so far and I'm very happy with them.
Thanks to everyone for your input. Dave |
Glad to hear that the problem is solved. I can recall some anxious moments when I did the same thing (only with 225s).
Me like track days
Right on. Glad it is fixed.
I looked at it in person, and even with the wheels straight ahead it was as if the wheels were shifted forward -- or the structure built rearward. Had me baffled!
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
