-   -   front hub collar thingy (http://forums.pelicanparts.com/porsche-911-technical-forum/214640-front-hub-collar-thingy.html)
Ron.G 04-05-2005 06:08 AM
I removed my front disks last night and when I loosened the allen bolt in the collar for the front hub I could back it out by hand.
Question: When I reinstall it do I just hand tighten it untill there is no play in the front hub and lock it down?
Or should I use channel locks to snug it up then back it off a few times to seat the hub?
Gotta love those dust covers! I guess Germans hate dust.:D
widebody911 04-05-2005 06:54 AM
I found out the hard way that you don't want it too tight; the bearings expand slightly when they get hot. I ruined a set of bearings in a single track day; ruined is putting it mildly; I had 1/4" of play in the road wheel by the time all was said and done!
kqw 04-05-2005 07:00 AM
Tighten it down to seat the bearing and back it off slightly; just enough to where the slot washer can be moved using a screw driver.
Ron.G 04-06-2005 05:44 AM
Thanks!
