Recreational User
Check out my new fan foil timing sticker!
Yeah, big deal, yet another fan foil timing sticker...
![]() Looks just like the others posted: ![]() Except for one thing, I made in on my HP OfficeJet printer about 20 minutes ago! Sometimes I'm just too damn clever for my own good! |
- Self Moderating -
Very cool!
Tim Present: 57 Intermeccanica Speedster Ivory on Brown Past: 85 911 Carrera Coupe Silver on Black, 57 Intermeccanica Speedster White on Tan |
Senior Member
Darryl,
Ok.. how did you do it? Looks very nice!! JoeA
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
That's AWESOME !!!!!
I need one for my '70 E and they are NLA !! Any chance I could sweet talk you into creating a couple for some of us early fellas ???? You can PM me for any photos or further info... Thanks !!
Richard W. Red '70 E, 2.2 White (w/ Red & Blue), '82SC, "Frankenstein" -a bit tweeked |
Recreational User
Hey Joe!
I "prospected" with Google and found a source for 8.5" x 11" permanent adhesive backed sheets of gold foil label stock on the Internet for $4.24 / sheet. A little light Photoshop work to "knock-off" the foil timing sticker data and Porsche crest. Print it onto the foil label sheet using the extra slow "glossy photo paper" setting on my HP OfficeJet printer. Be very careful to avoid smudges and fingerprints, let that ink dry really well. So the real problem to solve is how to keep the ink from rubbing off. The solution, run the foil label material through a plastic laminator (like those used to make business card luggage tags) while the backing is still on the label material. After it's laminated, cut the "foil decal' to the desired size, now the front is covered with a baked-on layer of plastic, and the back layer of plastic comes off with the label backing paper! Now if that ain't clever, I'll go back to bed! Last edited by DarrylD; 04-01-2005 at 06:14 PM.. |
Wow!
You can make up what will be correct numbers for a modified engine now... Does it have moving parts like your other 'diagrams'?
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
Recreational User
BTW: In case it isn't obvious in the first posting, the top label stuck to the fan ring is my knock-off, the second photo is the real thing.
This is still in the prototype stage, I'd like to make sure the things are fairly waterproof and stay on well before going into the sticker counterfeiting business.... I figured I have an endless supply if they don't weather well. |
timeless beauty
DarrylD,
Did 87's have that type sticker on the fan housing?
Bob 87 targa |
You continually amaze me Darryl. That's what comes when you get a little too much artist, a little too much techie, and a little too much Porsche-lover in the same brew. Keep it up!
ianc
BMW 135i. Nice. Fast. But no 911... "I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79 |
Daryl,
I noticed that one sticker has vacuum line disconnected and the other one has connected. Whick one is it??? Ron |
Banned
i smell a letter from pcna.
OR, is this some april foo's thing? |
ianc
Bird. It's the word...
Yeah, that's clever....
John Forcier Current: 68L 2.0 Hotrod - build underway |
SO which is which? Both look the part to me! You are in SUCH trouble! Do you know how fast your PM box will fill up once Pelicans get word of this!?!?!
Jake Gulick, Black Rock, CT. '73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B] |
timeless beauty
SoCal911SC
Bob 87 targa |
Thanks for the reply. I did not notice that. It is good to know that 1980 prior cars require that you leave the vacuum hoses attached.
Thanks, Ron |
Neil Peart Fan
I vote Daryl for President of PCNA
timeless beauty
I second that!
Bob 87 targa |
timeless beauty
I need that sticker on the engine compartment blower fan duct. I think its a Shell Oil sticker. Have a pic of that?
Bob 87 targa |
Banned
Now, what's your follow-on label triumph going to be
