-   -   *ALIGNMENT - post Elephant install - specs (http://forums.pelicanparts.com/porsche-911-technical-forum/214696-alignment-post-elephant-install-specs.html)
Craig 930 RS 04-05-2005 12:00 PM
Alignment after Elephant install -
Got your reading glasses on? Ridiculously hard to read:
http://forums.pelicanparts.com/uploa...1112727510.jpg
2.2 neg camber front, 2.8 rear.
This was the max they could get side-to-side
Blend this post with these others:
http://forums.pelicanparts.com/porsche-911-technical-forum/212875-corner-balanced-numbers-weight.html
http://forums.pelicanparts.com/porsche-911-technical-forum/212776-elephant-rear-suspension-install.html
http://forums.pelicanparts.com/porsche-911-technical-forum/212436-elephant-polybronze-bushing-install.html
don911 04-05-2005 12:03 PM
Are you using the elephant upper monoballs? 2.2 is really good. I was able to get -2.0 using the wevo camber king mono ball set up.
Craig 930 RS 04-05-2005 12:15 PM
I bought the Smart Racing m-ball setup --- RIGHT before Hayden came out with his setup.
I wish I had more than 2.2 up front - especialy since the JRZ struts supposedly ahve 1+ degree negative camber built in.
Don - How well does 2.0 work with the Proxes RA/1s?
MuffinMan 04-05-2005 12:19 PM
You can always add the Elephant Racing offset ball joints. I have them, and they supposedly yield up to 3/4 degree of additional negative camber.
Chuck Moreland 04-05-2005 12:29 PM
2.2 is much more than a factory setup would allow, so yes your spindles are de-cambered.
Jack Olsen 04-05-2005 12:41 PM
2.2 is more than I run in front, and I sometimes think I'm running too much negative.
911teo 04-05-2005 12:49 PM
How far would u go for a street/track car? I was thinking -1.6 -1.8on the front was already a lot.... -2.2 must wear your tires up very very quickly...
Craig 930 RS 04-05-2005 01:41 PM
I've been running about 2.0-2.2 for a year now.
For some street use and lots of track use with A032R tires, it has yielded perfectly even wear across the tread.
YMMV, depending on use and tires -
Wil Ferch 04-05-2005 02:20 PM
Hey Craig....your (reminder) post quoting A032's reminds me of the long-lost discussions we had with the "Toddler" on Rennlist....
Ahh....the old days !!! ..... LOL !
Wil
rattlsnak 04-06-2005 05:51 PM
Depends on how wide your tires are also. I just aligned my today, with just monoballs and stock mountings, and the most i could get was -1.6 in the front.
Rufblackbird 04-07-2005 12:45 AM
what exactly is the "preferred" alignment settings for a street/track combo car?
randywebb 04-07-2005 12:07 PM
There won't be an 'exact' one -- just take your pick on the Axis of Compromise.
Plavan 04-07-2005 12:37 PM
I have 3 degree's (raised bilsteins with camber added) in the front and 2.5 in the rear. I love it. Strictly for a race car though
Jeremy Cottrell 04-07-2005 12:48 PM
Jack, I don't think that's true. You're running -2.25 up front, IIRC.
