911 Oil Cooler Project - Part 2
Here is the finished project
Sergio The GT Lid Whisperer PCA 42yrs - National DE Instructor / Ex-RGruppe #197 '19 718 Cayman S (9th Porsche/1st with PDK) '14 Subaru Forester XT (Porsche support vehicle) |
Rubber isolating mount:
Cooler box and lines still allow mount space saver spare: Oil lines connected to stock firm lines and run through battery box: Cooler tucked in well behind bumper:
Nice job, Sergio! Where did you get the material for the rubber isolation mounts? Are those the mounts that came with the RX7 cooler (if it's an RX7 cooler, that is)?
Rob Fusi 77 911S | 3.6 Varioram | Triad Muffler | B&B 9400 Cooler |WEVO everything | Big Reds | 23/33 | 22/22 sways | Polybronze | RSR shocks/struts | FM10s | GTC Motorsports |
Rob - The cooler is indeed a Mazda cooler. The ends of the cooler were cut off and the thermostat discarded. New larger ends were fabricated with a larger inlet and outlet. The rubbber isolation mounts were cut off the original ends, drilled through for bolts and reused.
While I did cut the opening in the tub and formed the sheetmetal, I cannot take credit for the welding of the aluminum nor the sheetmetal. This work was done by Tom Martinot at Duetsche Motorsport in Concord, CA.
Senior Member
Sergio,
Very nice! Do you have any other pictures of the actual connections to the oil cooler as well as the notch for the cooler? I was getting ready to do my front cooler and have the hoses outside the tub, but after seeing yours would like to see if it might work better.
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Here are some pictures of the actual connections to the oil cooler as well as the notch for the cooler:
Designer King
Sergio,
How about a wider shot showing the whole front view of the car?
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
Here you go Paul:
That's as wide as it going to get. It's rain and I'mm still in my robe and slippers.
Nice job! I understand you just finished the job, but I'm sure you already tested the car, have you noticed the temp difference before and after?
I am going up to Thunderhill this weekend. Before the cooler, on a cool day with just a trombone, it ran 210.
Anyone interested in a concours correct trombone?
looks great!
well done!
X/A |
What size spare is that?
Sergio, what do you estimate the cost to be?
Thanks, David
99 996 C4 11 Panamera 4S 83 SC Targa converted to a 964 cab (sold) 67 912 (sold) 58 Karmann Ghia choptop (traded for the 912) |
19 years and 17k posts...
Very nice setup you have there!
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
I ran at Thunderhill this weekend and the oil temp was at 180 - on a similar weekend last year, it ran 210 without the cooler set-up. As for the cost, the cooler itself was $50 from a RiceRocket salvage yard. As for the rest of the cost - its hard to say. Steel braided oil lines, 6 A/N fittings, sheet metal, four days of cutting/fitting and some very nice welding by the Master. The spare is a 165/70-16. I believe that it came from aC2/4.
Unless this is a dedicated track car....how do you handle the fact that the oil lines go through the body ( now) toward the front cooler...how do you prevent water / cold outside air, etc, etc..... to get in the trunk area ?????
Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Wil,
I plan to stuff the holes around the the oil cooler lines and hole in the battery box with black tar-like strips that can be formed around the openings. I have used these with good success in other cars. I have to admit that I don't drive this car in the rain much.
Congratulations, 30 degrees cooler makes a huge difference on the engine life and "pushing" comfort.
