Ben M's Avatar
RS Clone Owners - Muffler / Bumper Clearence ??
When installing the RS fiberglass bumper (72 T) it hit the OEM muffler on a 3.2 89 engine, so I order a performance muffler from B&B, maybe my first mistake. The muffler sits aprox 1 1/2 inches low and aprox 1 inch to far from the engine. Have others run into this problem and modified the intake of the muffler, or ??
Thanks for any assistance.
Ben
Old 04-09-2005, 07:25 AM
Same problem here Ben mine hit the oem muffler aswell but only on the bolts from the exhaust-straps. I rotated the straps up and that solved the problem. Next problem is that the exhaust tip hangs about 1 1/5 too low like you discribed. I cut the tip of mine and will weld it in the right position. Not done yet but i will take some pictures if i do. My car is a g50 like yours so things should work for you aswell.
Cheers,
87 Carrera Backdate
Old 04-09-2005, 09:04 AM
Ben M's Avatar
BUMP
Old 04-09-2005, 03:46 PM
Administrator
Jack Olsen's Avatar
Is it too late to return the muffler? I wasted a lot of months and a lot of money on a B&B muffler. You have to do quite a bit to it to get it to fit a pre-1990 911. Then it will start cracking, under any kind of hard use.
Good headers. Bad muffler.
Old 04-09-2005, 09:38 PM
Ben M's Avatar
Jack & Ed,
Thanks for your help. I've installed it several times, so I doubt they will take it back, I try on Monday. Which muffler fits?
Ben
Old 04-10-2005, 10:01 AM
