How do I run a carfax on a Grey Market Car
I'm looking at a 79SC with the vin of 9119302686. It's a grey market car. I've heard that if you put WPOZZZ in front of the number, that is the actual vin. The problem is it is only 16 digits. I believe Carfax needs 17. Help!
Regards, Jim '86 Carrera Coupe |
The WPOZZZ serial number started in 1981. Try just using the actual VIN and see what happens. If it doesn't work, then add the WPOZZZ?
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
Team California
Carfax only works on 17 digit, (1981-up?), cars. So in this case, the ROW doesn't matter. On newer ROW cars I am pretty sure that it does not work either.
Denis |
That's sort of what I thought. Thanks for the quick responses!
Go Speedracer, go!
1981 SC ROW Coupe Last edited by SpeedracerIndy; 04-10-2005 at 08:10 PM.. |
Registered abUser
... one slight problem is carfax interprets kilometers as miles in the reports. So if your RoW has a km/h instead mph speedo, you need to take that into consideration. |
DP935 member
CARFAX Check Results
The Vehicle Identification Number (VIN) you entered, 9119302686, is invalid. Please check the number for accuracy and try again below. The letters "I", "O" and "Q" never appear in a VIN. The VIN must be exactly 17 characters in length. The vehicle year must be 1981 through the present. ----------------------------------------------------------------------------- The cars need to be a 81 or newer to check. I dont know if there are any way to check pre-81 cars. I would like to know that too if anyone knows.
Porsche Slantnose M505 M506 group on Facebook. https://www.facebook.com/groups/719995181372494/ |
As metioned above, if you enter WPOZZZ in front of the vin, it may work. Anyway since it is a 79, maybe carfax just won't run it.
Go Speedracer, go!
Straight from the source:
1981 SC ROW Coupe Last edited by SpeedracerIndy; 04-11-2005 at 07:51 AM.. |
SpeedracerIndy - Thanks for the final answer!
DP935 member
Yes thanks SpeedracerIndy. Good information to know.
