How do I run a carfax on a Grey Market Car
I'm looking at a 79SC with the vin of 9119302686. It's a grey market car. I've heard that if you put WPOZZZ in front of the number, that is the actual vin. The problem is it is only 16 digits. I believe Carfax needs 17. Help!
Regards,
Jim
'86 Carrera Coupe
Old 04-10-2005, 05:10 PM
Oh Haha's Avatar
The WPOZZZ serial number started in 1981. Try just using the actual VIN and see what happens. If it doesn't work, then add the WPOZZZ?
Pacific Blue
Wayne
Old 04-10-2005, 05:21 PM
Team California
speeder's Avatar
Carfax only works on 17 digit, (1981-up?), cars. So in this case, the ROW doesn't matter. On newer ROW cars I am pretty sure that it does not work either.
Denis
Old 04-10-2005, 05:37 PM
That's sort of what I thought. Thanks for the quick responses!
Regards,
Jim
'86 Carrera Coupe
Old 04-10-2005, 05:39 PM
Go Speedracer, go!
SpeedracerIndy's Avatar
It worked on mine. The records start when the car was imported into the US.
1981 SC ROW Coupe
Old 04-10-2005, 08:05 PM
Registered abUser
TerryH's Avatar
ditto
... one slight problem is carfax interprets kilometers as miles in the reports. So if your RoW has a km/h instead mph speedo, you need to take that into consideration.
'81 911SC Coupe SOLD
Old 04-10-2005, 09:26 PM
DP935 member
kycarguy 935's Avatar
CARFAX Check Results
The Vehicle Identification Number (VIN) you entered, 9119302686, is invalid. Please check the number for accuracy and try again below.
The letters "I", "O" and "Q" never appear in a VIN.
The VIN must be exactly 17 characters in length.
The vehicle year must be 1981 through the present.
The cars need to be a 81 or newer to check. I dont know if there are any way to check pre-81 cars. I would like to know that too if anyone knows.
Porsche Slantnose M505 M506 group on Facebook.
https://www.facebook.com/groups/719995181372494/
Old 04-10-2005, 11:16 PM
As metioned above, if you enter WPOZZZ in front of the vin, it may work. Anyway since it is a 79, maybe carfax just won't run it.
Regards,
Jim
'86 Carrera Coupe
Old 04-11-2005, 06:22 AM
Go Speedracer, go!
Straight from the source:
Q: Why can I not obtain a CARFAX Report on vehicles made before 1981?
A: We are unable to provide you with vehicle history information for vehicles manufactured prior to 1981, when the 17 character VIN became standard. The 17 character VIN is the code that is used to access CARFAX’s vehicle history information database.
To our knowledge there are no sources from whom pre-1981 vehicle history information is available readily. You could try to contact vehicle-specific clubs or groups focused on older vehicles.
We wish we could have helped you more. Please let us know if there is anything else CARFAX can help you with.
So if it's before 1981, you're out of luck
1981 SC ROW Coupe
Old 04-11-2005, 07:48 AM
SpeedracerIndy - Thanks for the final answer!
Regards,
Jim
'86 Carrera Coupe
Old 04-11-2005, 08:21 AM
DP935 member
Yes thanks SpeedracerIndy. Good information to know.
Old 04-11-2005, 09:27 AM
