Any idea on how much I can expect to pay a mechanic to replace my rear sway-bar brackets?
My friendly local muffler shop re-welded my broken one for free. That "fix* has lasted 10 years so far.
Mike
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
I had the old ones cut off and the new upgraded brakets welded on. The total came to about $200.00.
That was at the best body shop in SLC last year.
Regards, Jim '86 Carrera Coupe |
I was quoted close to $400 (Canadian) or $325 USD for just one side (bracket). Not sure if something is wrong with this picture.
I made my own brackets from 1/4 structrual angle steel, then migged them in place, I used the factory ones for a template to drill and mount the captive nuts to the new mounts.Total cost was about $6.00.
84' Steelslantnose Cab. 1953 Dodge B-4-B-108" 90,127 miles 1953 Dodge B-4-C-116" 58,146 miles 1954 Dodge C-1-B8-108" 241V8 POLY 1973 Roadrunner 440-SIX-PACK* 1986 F-250 Super Cab-460 V8 tow Newest additions- Matching numbers 1973 340 Road Runner!! 1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles others... |
I've paid $ 400, twice, to have mine done. Make sure you are dealing with someone that has done this mod before, or welds a big hunk of metal on there.
1973 911T Sepia Brown MFI 1986 Carrera Meteor Gray Metallic |
Senior Member
IF the old ones can be rewelded $50-$100. IF you need a new set - 2x-4x the price.
Targa 88 www.pelicanparts.com/gallery/targa88 There is speed.... and then there is VELOCITY |
