Mono Balls and Strut brace install help
I just purchased a used set of ER mono balls with the camber plates. The seller also gave me a strut bar and brackets.
Do the factory camber adjustment plates get completely removed when the new plates go in? Are the factory bolts long enough to use or do these need to be replaced.
Does the strut brace bracket ride under the camber plate or on top of it?
Just thought I'd ask here before I took things apart.
Thanks for any assistance
Old 04-11-2005, 09:47 AM
Chuck Moreland's Avatar
If you have monoballs with camber plate, then you can completely replace the factory parts. If you have just monoball cartridges, they are fit into the factory camber plates.
The answer on your strut brace depends on who made it. It doesn't sound like an Elephant Racing brace.
Chuck Moreland - elephantracing.com - vonnen.com
Old 04-11-2005, 11:08 AM
