brett25's Avatar
Replaced Bush (ings)
Hey. Over the weekend I replaced all of my shifter bushings using Waynes book. For anyone who hasnt done this easy and cheap update, I highly recommend it. It will really improve your shifting dramatically. All I have to do now is tighten up the clutch cable. I need to take up slack from the pedal end, and I didnt feel like fighting the carpets anymore, so thats for next weekend.
I noticed that there were two different suggestions for aligning the coupler with the shifter. Wayne had one method and Bob Tindel has another. Anyone have some suggestions?
B
Old 04-11-2005, 12:43 PM
Virginia Rocks!
VaSteve's Avatar
Re: Replaced Bush (ings)
B
I did this yesterday with the brass bushings and found the method in the Bentley manual to be the easiest to follow.
Well, well worth the time.
When you say "all of the shifter bushings" did you do these parts as well?
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 04-11-2005, 01:26 PM
brett25's Avatar
I did: the coupler bushings, the shift rod bushing, the ball cup bushing- there are others? Oy vey.
Old 04-11-2005, 01:44 PM
Is this a 915 only mainteneance issue? Which bushings can be swapped on the G50?
Old 04-11-2005, 02:01 PM
brett25's Avatar
Cool
yeah this is for the 915, Im not sure about the G50- I didnt think that you guys had any shifting issues.
B
Old 04-11-2005, 02:42 PM
