Question about early 911 flywheel
About to install a new flywheel and I realize that it does not have the boss/hub for the pilot bearing. I tried a few blows with a brass hammer without any movement. Is this a press/interference fit, right? Do I need to heat or cool it for better results? Thanks in advance.
PS - anyone know how to have the ring gear replaced on these 901 tranny flywheels?
Joe Riley 84 Carrera Targa 69 911S Coupe Click here for 911S project "updating as I go" Last edited by Joe911; 04-11-2005 at 03:09 PM.. |
Navin Johnson
Should go in easy with a press..
I like lightened flywheels
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Crusty Conservative
In 1969 the ring gear was integral to the flywheel. Measure the thickness of the contact surface to be sure you don't need to replace the flywheel anyway.
Bill 69 911 T Targa, 2.4E w/carbs (1985-2001) 70 911 S Coupe, 2nd owner (1989- 2015) 73 911 T Targa, 3.2 Motronic (2001- ) |
the new pilot bearing comes with that piece. they just wack out with a large.plastic hammer. same to install.
I knew that on the ring gear is machined on the early flywheels – therefore no replacement part. But I have heard rumors (I can't remember where) of milling it off and replacing with a separate ring gear. This one is similar to the 906 units and I hate to loose the use of it. Consequently it is worth spending the $$ to get this done if it is possible.
JOHN – thanks, I did not know it came with the pilot bearing – I expected to just get a needle bearing. I try not to beat on things when I don't know what I am doing. I will proceed with a new one.
Joe Riley 84 Carrera Targa 69 911S Coupe Click here for 911S project "updating as I go" |
