-   -   replated spring plates - what to do w/ inside? (http://forums.pelicanparts.com/porsche-911-technical-forum/215782-replated-spring-plates-what-do-w-inside.html)
Dixie 04-11-2005 04:10 PM
Are you supposed to grease the inside of the spring plates? You know, where the torsion bars go?
Here is why I ask...
I got my freshly replated spring plates back (yellow zinc). What I discovered is that normal electroplating does not plate inside the spring plate due to it's shape*. Unfortunately, I do not recall if the inside was plated from the factory. But I do recall the inside was rather rusty. Either way, I'd like to keep the inside from rusting further.
I can't be the first person to run into this. What is the solution?
(I'll post pictures later.)
Thanks in advance...
*FWIW: To plate the inside of a cup-like part, such as the spring plate, you need to have the parts plated using a different process. I believe they called it a non-electrode process?
Evans, Marv 04-11-2005 04:25 PM
The inside isn't usually plated. Plating might make the dimensions of the teeth inside too small to take the torsion bar splines. I'm storing mine until I can put the car back together & sprayed fogging oil inside to keep the splines from corroding again. I think I'll put antiseize on them when I assemble them, unless somebody with more knowledge about that pipes up & gives reasons not to.
imcarthur 04-11-2005 05:21 PM
You plating guys . . .
I just finished mine. Just lightly grease the inside with the grease you use on the torsion bar. I used a greased rag on a paint stir stick. You won't need antiseize.
I went cheap & fast & just rattle-canned . . .
Before:
http://forums.pelicanparts.com/uploa...1113265173.jpg
http://forums.pelicanparts.com/uploa...1113265211.jpg
After:
http://forums.pelicanparts.com/uploa...1113265227.jpg
Ian
450knotOffice 04-11-2005 05:44 PM
Those look nice! What kind of paint did you use? I'm pulling mine in about a week or so.
Thanks.
imcarthur 04-11-2005 05:57 PM
Scott
Tremclad Rust Paint. Aluminum color.
It ain't as cool as plating but my 'selling' to the wife is growing thin at the moment so . . .
Ian
