Southern Class & Sass
Are you supposed to grease the inside of the spring plates? You know, where the torsion bars go?
Here is why I ask... I got my freshly replated spring plates back (yellow zinc). What I discovered is that normal electroplating does not plate inside the spring plate due to it's shape*. Unfortunately, I do not recall if the inside was plated from the factory. But I do recall the inside was rather rusty. Either way, I'd like to keep the inside from rusting further. I can't be the first person to run into this. What is the solution? (I'll post pictures later.) Thanks in advance... *FWIW: To plate the inside of a cup-like part, such as the spring plate, you need to have the parts plated using a different process. I believe they called it a non-electrode process?
Dixie Bradenton, FL 2013 Camaro ZL1 |
The inside isn't usually plated. Plating might make the dimensions of the teeth inside too small to take the torsion bar splines. I'm storing mine until I can put the car back together & sprayed fogging oil inside to keep the splines from corroding again. I think I'll put antiseize on them when I assemble them, unless somebody with more knowledge about that pipes up & gives reasons not to.
Marv Evans '69 911E |
Used Up User
You plating guys . . .
I just finished mine. Just lightly grease the inside with the grease you use on the torsion bar. I used a greased rag on a paint stir stick. You won't need antiseize. I went cheap & fast & just rattle-canned . . . Before: After: Ian
'87 Carrera Cab ----- “Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.” A. Einstein ----- Last edited by imcarthur; 04-11-2005 at 05:23 PM.. |
Those look nice! What kind of paint did you use? I'm pulling mine in about a week or so.
Thanks. |
Used Up User
Scott
Tremclad Rust Paint. Aluminum color. It ain't as cool as plating but my 'selling' to the wife is growing thin at the moment so . . . Ian
'87 Carrera Cab ----- “Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.” A. Einstein ----- |
