Current California smog exemptions HELP!!
Hi guysl
It's been a while since I lived in Cali,, I am in Florida thinking about coming back to San Diego; I have a 1978 SC and I can't seem to find a straight answer on what the smog exemption rules are for old classics; Anyone in Cali that has a clear legal answer please let me know, TIA
78 911 SC "Scratchy" 2004 Mini Cooper S "Pele" (gone but not forgotten) 1979 classic mini clubman-"Coolio" |
1975 or earlier are exempt, your 1978 will need to be smogged. There have been some threads on registering it as a collector car which need not be smogged, but it seems rather a long shot - maybe someone will chime in on whether that is still possible and if anyone has successfully done so.
unless you have a smog tech in your back pocket or an address way out in the sticks, you're going to have to smog the SC.
any model year '76 and newer is subject to smog tests every 2 years...
1971 914-6 GT 3.6 1974 911 1976 911S leaf green backdate 3.2 |
*No shrubs or trees were killed in the posting of this message. However a tremendous amount of electrons were terribly inconvenienced.* |
@Norm, btw Californians call it “Cal” (i.e. NorCal, SoCal, etc...) not “Cali”. Hope you get your CA DMV smog requirement sorted out soon. And welcome back to the “Left Coast”. Bem vindo de volta
I researched this issue before bringing in a 1988 911 I bought from a seller in Georgia. Your car will need to meet the emissions limits that the California Air Resources Board established for the MY 1978 911 SC which can be found here.
https://ww2.arb.ca.gov/sites/default/files/classic//msprog/onroad/cert/pcldtmdv/1978/porsche_pc_a0190013r1_3d0_ta0.pdf There is also a visual aspect of the inspection so it’s important to have the correct original ( or approved aftermarket) emissions control parts. |
All great answers guys and thanks for the Info A&J, on the terminology
![]() https://www.dmv.ca.gov/portal/uploads/2020/05/reg5103.pdf @Norm, Please verify with the CA DMV if this can apply to your situation while your 911 is in FL.
I had to smog my car and I don't know of any exemptions. 1975 was the last year of smog exempt so I think you are stuck. good luck |
do you have all the smog stuff on your engine ??You must have that to pas the smog in CA.
Air injectors to each cylinder alias xmas tree, smog pump,and i believe you need the catalyst.... Ivan this [IMG]httphttps://i.ebayimg.com/images/g/JzAAAOSwJkJWjCNo/s-l640.jpg[/IMG] ![]() 911 SC -- Air Tube
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. Last edited by proporsche; 01-27-2021 at 04:07 AM.. |
Banned
If your car was not originally a California car and you move to California, does the smog equipment need to be added, or just maintain what emissions equipment was originally installed?
Or, register the car in a boon-dog county where they don't require smog check, ever.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
you have to maintain an address in said boondock county. easier said than done.
CA is hip to all the shortcuts. they've even been cracking down on montana LLC's...
RETIRED
It used to be a rolling 30 year exemption. You can thank Sheila Keihl the lesbian gf from Dobie Gillis and Governator repealing that.
Pretty hypocritical coming from a guy that owned a Hummer with Oregon plates because it was illegal in CA. |
If the car is North American spec also known as "Federal" certified it does not need to be converted to California emission when being brought into California. But it does however have to meet California tailpipe emissions if the vehicle is 1976 or newer. There will also be a visual inspection to check for modified/missing/defective emission equipment. This process of emission testing or "Smog Check" has to be done every two years.
Red Line Service
As for the "rolling 30 year exemption", I believe it was talked about, but never actually happened.
Marc Bixen/Red Line Service West Los Angeles, Ca. www.redlneservice.net / info@redlineservice.net Podcast:"Marc Bixen Live" https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA |
RETIRED
Since I no longer live in CA and I retired as a air pollution specialist. I don’t keep up with the situation but I do know what happened when the repeal happened. It was discussed on this board in depth. |
Still here
https://www.bar.ca.gov/Consumer/Referee_Program/ Parts Locator Service The referee offers a service to assist consumers in locating parts that are difficult to find. If the part is unavailable, the vehicle may be eligible for a Limited Parts Exemption and must be inspected at a referee center. Need a Referee? Referee centers are centrally located within certain community colleges throughout California. To find a referee center near you or to schedule an appointment, visit asktheref.org or call (800) 622-7733. |
RETIRED
Lots of hoops to jump thru and IF the parts are available are very expensive. An associate of mine spent close to three thousand chasing parts that were in most cases worse than what he had. For a 76 914.
But you’re missing my point. If it wasn’t for Arnold and that twit senator cars up to 1990 would be exempt. |
![]() ![]() ![]() Sent from my iPhone using Tapatalk Pro
http://9309700485earlyturbo.wordpress.com |
