Porsche-poor's Avatar
CV Joint Question
Looks like I need to replace the seal on on the left rear side of the tranny. I was reading the Bentley book and am a little confused. The book gives torque settings for (3) bolts the M8, M10 and the flange bolt. Looking at the description on taking it apart I should have (2) bolts to worry about unless they are giving a setting for the M8's used to counter hold the flange while removing the flange bolt.
Is that the case or am I missing something?
'79SC Targa
'2021 CRV
Old 04-12-2005, 09:00 AM
Better in Person
juanbenae's Avatar
i would suspect your 79 has the 8mm allen head bolts. setting the emergency brake will keep the axle from spinning when tightening and loosening. they thread right into the flange out of the tranny.
it helps to have someone to set and release the parking brake as you rotate to access the bolts while you are under the car
Old 04-12-2005, 09:58 AM
So there is only two sizes of bolts?
'79SC Targa
'2021 CRV
Old 04-12-2005, 10:07 AM
Just reconnected my axles this morning... there's 6 bolts that connects the inner CV joint to the transmission. I used a 8mm allen key for these allen head bolts. The torque for mine is 60 ft-lb/83 Nm. I believe these are M10 bolts though.
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
Old 04-12-2005, 10:22 AM
Better in Person
juanbenae's Avatar
i only encountered the 8mm allen head. i think the 10 may refernce the 8 sided star type. the trade name is torques i think?? you can look under the car and prolly see the one you need.
Old 04-12-2005, 10:25 AM
jdowty3's Avatar
911 CV Joint Bolt, 10x48mm (1974-early '75)
911 CV Joint Bolt, 10x50mm (late 1985-89)
911 Turbo CV Joint Bolt, 10x60mm (1978-86)
911 CV Joint Bolt, 8x50mm (late 1975-early 85)
straight out of Waynes catalog page
Jim Dowty
97 911 Coupe (Forest Green metalic, sunroof, leather)
PCA RSR region Insurance chair and Board member
Gruppe B #309
Old 04-12-2005, 10:45 AM
Early_S_Man's Avatar
Porsche Crest
SCs have six M8 Allen bolts that use either a 6 mm Allen drive, or 12-point Polygon drive bit. It is the '69 thru mid-75 models that use 4 ea M10 bolts and two Spiroloc pins per CV joint.
Don't use the 60 lb-ft torque on M8 SC bolts ...or you will break [beyond yield spec] them!!!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 04-12-2005, 02:04 PM
Thanks for the help and directions.
'79SC Targa
'2021 CRV
Old 04-12-2005, 02:23 PM
Better in Person
juanbenae's Avatar
and oh yeah, recheck them after about 200 miles
Old 04-12-2005, 02:56 PM
