Disappointing track day
I instructed @ Thunderhill today with TrackMasters Racing Club. This was my first outing with the new home made roll cage , fiberglass hard top, lexan windows, etc, etc.
The good: The car ran great. The only things that even remotely resembled mechanical issues were some excess brake fluid resevoir overflow, and an errant bolt, that doesn't even look like it goes to the car, became lodged under the clutch pedal and wouldn't let the pedal come back up. After a couple of tire pressure tweaks, the car was sticking like like on it's new Kumhos, which I had mounted literally minutes before I left for the track. With the new cage, the car was much tighter and responsive, and much easier to drive. The fiberglass top "worked" great, no squeaks or rattles, despite having zero weatherstripping. My po' man's interior door handles worked well, and were easy for students to figure out. I put down 190 track miles in one day; in the afternoon, I drove 3 sessions back to back for 75 straight minutes of track time. In keeping with the April 15th theme, my ass is sore...
The bad? As hard as I tried, I couldn't break 2:10
More pix @ http://rennlight.com/cgi-bin/search.cgi?string=Thunderhill+2004-04-15
Old 04-15-2005, 07:49 PM
PRO Motorsports
Tyson Schmidt's Avatar
Dude, that is some sick rake on your rear wing. Doesn't it push like crazy like that?
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 04-15-2005, 08:09 PM
smstcoach's Avatar
Send a message via AIM to smstcoach Send a message via Yahoo to smstcoach
Thom,
I knew I lost something on that ride along. That was definitely different.
It was awesome to see what serious weight reduction can do for our cars. Mine felt like a fat pig in the last session. I'm ready to pull out a hack saw and chop my roof off.
-Jeff
Old 04-15-2005, 08:37 PM
Administrator
Jack Olsen's Avatar
Well, judging by the pictures, you looked the business out there.
And in my (limited) experience, that track has fast days and slow days. We should do another event where he trade cars for a session. It might be useful to see where the handling characteristics are different -- a kind of perspective check.
Old 04-15-2005, 08:59 PM
It pushed a little, but I dropped a couple lbs of air out of the fronts and it seemed to work OK. I had no clue as to where to set the angle, so I just WAG'd it and went from there. I'm on the steep side of the learning curve.
OTOH, nobody could touch me in turns 2 and 3.
Old 04-15-2005, 09:05 PM
smstcoach's Avatar
Jack,
I'll trade with you if Thom won't
-Jeff
Old 04-15-2005, 09:06 PM
ted ted is offline
likes to left foot brake.
ted's Avatar
Looks awesome in the corner.
What is the sweet spot for the banana wing, 7 to 12 degrees?
The photo looks like you have more.
A front splitter would seem to balance the added rear down force?
Car looks very good, compared to all the skillful time consuming improvements you have made a basic front spoiler would be simple.
I’d really like to try T hill and Sears this year.
When you coming down to Big Willow or Cal Speedway?
Old 04-15-2005, 09:22 PM
Administrator
Jack Olsen's Avatar
We've tried to get Thom down to Willow for a while now. One day, he'll see what a fast track is like.
Old 04-15-2005, 09:41 PM
PRO Motorsports
Yeah, you're aproaching the stall angle there. I'd just try backing it off one notch.
2004 GT3
Old 04-15-2005, 09:46 PM
I'm also thinking about lowering the whole assembly about 1"
Old 04-16-2005, 09:33 AM
Sports Purpose 911 Driver
mjshira's Avatar
Thom, I love your car man, MadMax meets 911.ROCKS!
James Shira R Gruppe # 271
1972 911 Coupe 3.8 RS ‘nbr two’
1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie'
1955 356 Pre A Coupe ‘old red’
1956 356A Emory speedster build in progress
Old 04-16-2005, 09:36 AM
PorscheGuy79's Avatar
Thom, how did those holes work out? Notice any reduction in temps or maybe noticeable drag?
Matthew
“Sometimes the questions are complicated and the answers are simple.”
Old 04-16-2005, 09:51 AM
Oil temps were normal, and I can't really tell about the drag, with the new wing, different top, etc. Apples to tractors. I'm only getting up to 130 on the front straight, but that could be a factor of the incorrect wing angle.
Old 04-16-2005, 10:56 AM
Administrator
Jack Olsen's Avatar
In my opinion, the rear holes aren't going to do anything for you. You've got a high pressure area above the decklid, and a low-pressure area behind it. Part of your rear downforce is generated by the disparity between the two. The engine blower also relies on the high pressure air up top as a source for cooling air. The low pressure region in back is only going to be pulling air away from the blower. In a worst-case scenario, you're now reducing rear downforce, and diverting cooling air from above the decklid to behind it, reducing the volume of air for cooling the engine.
(Of course, my opinion should be taken with a large grain of salt, as I'm the furthest thing from an expert on aero.)
I think it's a different story down by the muffler.
And that's one of the coolest-looking rear ends you're going to find on a 911.
Old 04-16-2005, 11:44 AM
DP935 member
kycarguy 935's Avatar
I found this aerodynamic wind tunnel simulator if anyone is interested. It may answer some questions about high/low pressure and downforce.
I havent tried it and have no affiliations.
http://www.kineticart.co.uk/WindStudioSimulator.asp
Porsche Slantnose M505 M506 group on Facebook.
https://www.facebook.com/groups/719995181372494/
Old 04-16-2005, 04:42 PM
