Help with my co/hc please
My 3.3 turbo can't seem to run unless very rich. The minute I start to lean out the motor it revs up and down. Is there an initail starting point for adjustment ? My sidedraft m.g's would start with ten turns rich from full lean and then you would start fine tuning, anything similar for these motors ?
1986 blk 930 2000 expedition 2000 bmw 3 series convertable 1996 Silverton 312 sedan bridge Last edited by steven polaski; 04-16-2005 at 04:11 AM.. |
oscillating idle -> vacuum leak or bad recirculating valve gaskets
Thank you for your time, |
Designer King
Oscillating idle on NA cars usually means a too rich mixture. Is it the opposite for turbos?!
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
mine settled after tightening hoses and replacing recirculating valve gaskets.
