Total Destruction
The other day I took apart a core motor that was just laying around the shop - you know, to see what it was. I could see the broken #6 intake valve through the port, so the question was how bad had the motor been damaged. Check out these pictures:
The case was also hosed where one of the bearings started to spin and literally melted away the main. Pretty cool stuff.... |
The question I always have when I see something like this here...is how did it get that way? What led to that destruction? What could have been done to avoid it?
drag racing the short bus
Marco! What's up, Chief? Tony lets you play with his tools? Did he put my old calipers on his 356 yet?
The Terror of Tiny Town |
Formerly bb80sc
Looks just like the piston head I keep on my desk as a paperweight.........and a reminder to ALWAYS turn the motor over by hand BEFORE using the starter
![]() -B
Cheers -Brad 2015 Cayman GTS 2015 4Runner Limited |
Nothing a little Marvel Mystery Oil couldn't handle, ahem ! Doug
David, yes, the car is about done. Here's a picture from most people's perspective.
Looking good. Tell Pops I said "Howdy!"
PRO Motorsports
Valve guides wear out, valves now lose their ability to conduct heat away from the head through the stem and out through the cylinder head. This causes the valve head to heat-fatigue and break off from the stem and the mayhem ensues.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
OH. This is why we should rebuild our Carrera (or SC) engines once the oil consumption gets down to 1 quart for every 500 miles or less etc. I get it now... ![]() BTW...Tyson, is your shop good at rebuilding 915 trannys? My car is getting to the point of needing it. |
Hey, Tyson, I don't even get a hello? Thanks for nothing ...
You headed up north at the end of the month? |
The last one I too apart that looked like that was shoved into second gear at about 75 mph. What was left of the exhaust valve was bent into an "S" shape!
DAvid Duffield |
PRO Motorsports
Hello Marco! Sorry Bro'. Yeah, I'll be there. Driving my new car with lots of new upgrades. I'm looking forward to this year's event. I'll be an official member soon. See you there!
PRO Motorsports
Yes, I rebuild a lot of them. From stock to race, whatever you need. The 356 boxes we send to Marco's papa. (Tony @ TLG)
Good, good Tyson. Looking forward to bench racing with you.
I can't wait to see what you've done with the new toy, too. |
Virginia Rocks!
What does this mean? With a wrench before each time you drive it?
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na Guards Red is for the Unoriginal
Team California
Some motors consume less, of course, but my "rebuilt to brand new" SC motor w/ better valve guides than original consumed ~1 qt. per 500 miles.
Denis |
Team California
I just thought that it was important to correct that statement right below it for the whole *Pelican data base* thing here.
Once again: 1 quart of oil consumed every 500 miles in an air-cooled 911 does not equate to rebuild time. It equates to brand-new, properly broken-in car/motor. That sounds like a Motor Meister ad: "911 burning a quart every 500m ? Bring it in for our spring special, the KY jelly rebuild....." ![]() The cliche w/ a 911, was that the factory recommended oil changes @ 6000 mile intervals, but that the customer had "changed" the oil once in between. (Get it? 1 qt. every 500 for 6000 miles = 12 new quarts in between).
Denis |
Team California
Denis |
