I need pictures of a 964 and sc spindles
I need pictures of a 964 and asc spindle ball joints and what ever else you may want to post, Thaks, Kevin
PRO Motorsports
Are you trying to compare them to see if you can swap 964 suspension onto an SC? If so, it ain't gonna be easy! They are totally different.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
These are 964, not stock but you get the idea
Actualy tyson this is what im looking at doing, I have a wide body and cant stand the spacers,
I am going to cut and widen the sc lower control arm to get the width im looking for, If I remember right you had to have Jacks spindles cut because of camber problems, using a 965 spindle and coil over on a altered sc lower is my idea, this will allow me to use late model brakes and get rid of the spacers etc, the spindle should already have the correct camber in it (with out having to alter it, i know camber will have to be set), i feel the biggest problem will be the ball joint, I wish i lived out west the land of the P car i could compare parts at junk yards, Ideas , let me know, Kevin |
964 suspension stock except for the HR stage 2 springs
Thannks jtkkz
