Senior Member
Turn turn signal issues......70 911E
I have been chasing this one off and on for some time, and it is time again to try ans sort this one out. My passenger side front side marker and turn signal go bright when I use my brakes. Almost like a front brake light. Additionally, when I use the turn signal to turn right normally, I get two flashes, and then both indicators flash on the gage. EE was not my strong suit in school, hoping for a semi-simple solution?
Thanks.
Chris
1988 911 Carrera Targa (driving project started JAN 2022)
1970 911E - Long since gone
1972 911 Targa - gone
1987 911 Carrera - gone
Retired FA-18C Driver
Old 04-16-2005, 06:47 AM
jluetjen's Avatar
Bad ground. I'd take apart the rear directional assembly and clean and confirm that all of the connections are clean. I just did mine because I had a similar problem on the left side. The directionals worked fine until I put the brakes on and then they would go dim. The brake lights worked fine and the directionals worked fine, just not together.
In case you're a non-electrical type like I am, a couple of observations.
1) The ground path is through the pot-metal directional bucket and the mounting screws into the chassis. So I also made sure that the threads were clean on the screws. Also clean off where the screw heads contact the bucket. There may also be another grounding path through the brown wire, too depending on the configuration, so I also cleaned those connections.
2) I don't know what other people use to hold the backing plate on, I just used some silicon bathroom caulking.
It fixed the problem.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 04-16-2005, 07:58 AM
