Help with my co/hc please
My 3.3 turbo can't seem to run unless very rich. The minute I start to lean out the motor it revs up and down. Is there an initail starting point for adjustment ? My sidedraft m.g's would start with ten turns rich from full lean and then you would start fine tuning, anything similar for these motors ?
1986 blk 930
2000 expedition
2000 bmw 3 series convertable
1996 Silverton 312 sedan bridge
Old 04-16-2005, 05:04 AM
beepbeep's Avatar
oscillating idle -> vacuum leak or bad recirculating valve gaskets
Thank you for your time,
Old 04-16-2005, 05:10 AM
Designer King
Paulporsche's Avatar
Oscillating idle on NA cars usually means a too rich mixture. Is it the opposite for turbos?!
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 04-16-2005, 07:37 AM
beepbeep's Avatar
mine settled after tightening hoses and replacing recirculating valve gaskets.
Old 04-16-2005, 12:23 PM
