-   -   rebuilt altenator noise (http://forums.pelicanparts.com/porsche-911-technical-forum/217041-rebuilt-altenator-noise.html)
steven polaski 04-18-2005 04:32 PM
I just put in a rebuilt alternator pretty easy except I now get this funky noise from the alternator. Took off belt no noise so not timing chains. Spin's easy by hand I wonder if alternator is crappy ? Also if I lower idle down to 700 r.p.m.'s noise goes away.
Bill Douglas 04-18-2005 04:41 PM
How about trying it with the belt not quite so tight and see how that sounds?
steven polaski 04-18-2005 04:53 PM
belt is loose 1 shim on the inside.
Bill Douglas 04-19-2005 02:30 PM
My alternator made a noise after I adjusted it to the correct spec's so I slackened it off so te belt had a lot of wobble, but not so much that it would flap around or slip, and this fixed the noise.
TerryH 04-19-2005 03:10 PM
If the alt was rebuilt locally, I would drive over and let them hear the problem. Then drive it for a week or two and see if it quiets down unless they suggest otherwise.
I've got my alt out getting rebuilt as we speak. Knocking on wood!!
RoninLB 04-19-2005 03:15 PM
I always use a truck or marine rebuilder. They have to use quality bearings. If you were looking for a cheap rebuild you should figure 1in8 rebuilt starters and alt's are one foot in the grave and the other on a banana peel.
steven polaski 04-20-2005 03:52 AM
The rebuilder is taking it back no questions asked and giving me a new one.
