BReyes's Avatar
1967 911 engine differences
911s v. 911
180 hp v. 130
why?
Thank You.
Regards,
Bernard
Old 04-17-2005, 06:23 AM
RETIRED
Joe Bob's Avatar
S cams and higher compression.....it's the motor "I" have in my 914/6.....FUN
2012 ML350 3.0 Turbo Diesel
Old 04-17-2005, 06:43 AM
The basics are used by most manufacturers to increase power. Different cam timing,higher compression ,bigger valves, larger ports,less restrictive exhaust,larger carbs,etc. Various mods to maintain reliability at higher power level such as forged pistons and crank instead of cast ,and better oil cooling. Porsche used all this and more , some changes eventually were adapted to lesser engines as years progressed.
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 04-17-2005, 06:49 AM
BReyes's Avatar
So basically have to determine what engines were in a given year 911, then when have a car to look at the numbers on the engine will tell me what case it is. Knowing what P&Cs/Comp Ratio, Cams would be based on service history or actually when I would tear it down to do a top end rebuild.
To me it seems like 50hp+ is important. Thanks for your input.
Regards,
Bernard
Old 04-18-2005, 05:26 PM
rrpjr's Avatar
It is more than a matter of hp. The 'S' -- from 67 to 73 -- is a disproportionately valued and valuable car.
1984 RoW Cabriolet - GP White
Old 04-18-2005, 05:33 PM
Actually it's 160 vs 130 hp. Cams, valves, pistons and a less restrictive exhaust system make up the difference.
John
Old 04-18-2005, 05:34 PM
