Need Help! Warm Starting Problem
My 84 Targa is having warm start problems! I've done a search and found the fuel check valve or the accumulator (on SCs) can cause this. Just replaced the check valve but the problem persists. If the car sits overnight - no problem starting in the am. But leave it 4-8 hours and two or three cranks are required before she fires up. Any other suggestions as to what can be causing this?
Thanks- Mike
1984 911 Targa 2001 MB 320 ML 1989 Isuzu Trooper 1973 911T (Sold) |
