Finding I don't possibly need the warm-up throttle...early 911
I don't know if it's because the weather is warmer here last several days, or something else. Finding the car starts immediately, goes right to around 500-700 without the use of the warm-up throttle, and then to constant 900-1000 or so shortly thereafter.
Normal, good, other? Thanks! |
well, it just sounds like it's not needed for very long. i'd still use it until it idles at 1000 without it. my '74 needs it for about 5-10 minutes..gradually reducing until closed by ~ 150 degrees on my temperature gauge.
ryan |
Since the rebuild, it reaches correct idle sooner. I'd prefer not to dump gas in there if not necessary.
I use my hand throttle when cold starting. After the car warms up, I don't need to use it, but I still do out of habit...
just a bit more chance of it loading up and fouling plugs if you don't use it. it's better to keep it around 1000 until it idles there by itself.
| All times are GMT -8. The time now is 08:03 AM. |
