i need some CIS help. starting to give up :(
ok, first off, i have checked my CIS pressures. they are all perfectly within spec
cold: 31psi @ 65 degrees system; 69psi warm; 53psi and the system holds at rest pressure for one hour @22psi (at this point i removed the gauge and buttoned everything up) PO installed MSD and all the acoutrements with it. car runs fine, starts great when cold BUT, when it is warm, it starts up perfectly fine, but it chugs and chugs at around 300-500 rpm. sometimes if i try to feather the gas, it does baby pops in the airbox. eventually, the revs come up, and i can motor away happily. i gotta get this fixed. AXing with all the hots starts can get annoying, and embarrassing. i thought it may be my accumulator, or check valve, but doesnt the good "at rest" pressure eliminate this? i am stumped. cliff PO did a tune up one year ago. |
maybe ignition related.
Fuel accumulator issues are typically when the car is hot and the car will not start. Does your exhaust smell like fuel? Have you tried removing/replacing the relay under the pass seat? Do you have another CD box you can test with? Sounds like a fun one....good luck!!
-B |
Just a thought,
This is purely speculation, but maybe your injector seals are leaking air. If the seals are leaking more with the engine warm, it would cause a lean mixture at high vacuum pressures at idle. |
Sounds like an accumilator.
AFJuvat |
yea, i was gonna toss in a new accumulator and check valve because they are both relatively cheap and easy to install. but i dont want to start chasing this with new parts. that could kill me, at least my wallet. still, the good residual pressure should eliminate these two items.
john, i considered a leaking injector, but maybe a seal is more probable. thanks. |
Vash,
Have you checked the operation of your AAR? I am also wondering if your cold start valve is leaking. Have you checked for smooth movement of the sensor plate? |
Be careful of those baby pops Cliff. That's how mine started and look at what I'm doing now!!!! I was lean and my wallet is angry.
Just last weekend, I replaced my fuel pump and accumulator and had the same problem. I then dicked around with the mixture and idle screw settings with only minor improvements.
I checked my point settings and they were way out. I reset the gap to .012" and it ran and started way better. Then I reset my mixture and idle screw and now it runs better than it ever did since I bought the car. The warm idle is still a little bit rough (missing on 1 cylinder) so I think I may have one bad injector. |
Have you checked things like the temp switch, throttle position switch, and frequency valve?
Could be ignition but that would not be my first choice.
I agree your tests rule out typical warm start problems (check valve, accumulator, etc). From your description is sounds like when you start it warm the mixture is way off. Popping through the intake usually means lean, but I'm not sure in this case. As previously stated, vacuum leaks are the first and obvious possibility. Then I would look at your cold start injector, AAV, and thermovalve. If the fuel injection thinks the engine is cold when it is actually warm, it would add too much fuel. When an engine is started hot, the air is not as dense, which usually makes it run a little richer than if it was started cold. If the mixture is already too rich, that would make it worse. The next time you start it hot and it stumbles, pull the air cleaner off and carefully lift the air sensor plate a little bit. That will basically add more fuel without adding more air. If the idle gets better, you are too lean. If it gets worse or dies, it is already too rich. If it's too rich you need to figure out why and correct it. If the cold start injector leaks, you could compensate a little with the mixture adjustment which would work OK when cold but not when warm. |
I have the same problem, when i first start the car, usually when it is cold, it will idle low, 500 or so, and the usually within a few seconds come right up to speed. If i give it any gas, it will pop and usually die. I just let it do its thing and not touch throttle and it works fine. I have a 83 CIS motor which i modified the CIS to remove the Lambda in a 78 though.
I suppose you could pull the injectors, have them cleaned and tested, then replace with new seals.
Even if all of the pressures are correct it may be possible that the injector(s) are bleeding down pressure in the lines between the fuel distributor to the injector itself. When you go to restart the engine at a warm temp (meaning without the cold start valve functioning) one or more injector line is repriming itself and maybe causing your symptoms. Just a theory, YMMV. Good luck. |
Cliff, if you need to drop the motor, lemme know. After next weekend I'll be an expert! ;)
Check the AAV its easy, first check for voltage with the car running then pull it and run 12 volts to it and see if it closes all the way. Easy to check for vacuum leaks with the carb spray method, I assume you did that. I think that will work on Injector seals too.
Oh check the diaphragm on the decel valve if you have not. its easy too.
if i recall correctly, another quick check is to simply remove the oil filler cap while running..it will let a lot of air into the sytem and should kill the engine, but if it's running extremely RICH, it probably won't die. anyone else recall the details of this check?
ryan |
No, it should stumble a little when you remove the cap, but not die. That's because of the whatchamacallit in the soft oil line that reduces the flow.
If it stumbles and pops and then dies when you give it more gas (air actually) -- it sounds lean. While it's stumbling and popping can you pull down on your throttle plate and see if it picks up.
vash,
I had the same problem with my 81 SC, with the symptoms you describe on your original post. The problem was a fuel leak on one of the metal fuel lines that ultimately connects to the fuel accumulator. It wasn't apparent to me, however, until I replaced the fuel accumulator and filter. Since your problem is prominent during warm/hot starts, I would strongly suggest you change your accumulator and filter (especially if you think they are old components anyway), as you had originally intended to do based on the relatively low cost of replacement vs. other more expensive fixes. This is based on the simple fact that the accumulator plays a key role in fuel pressure during warm starts. From what I have researched, messing with the fuel mixture is somewhat delicate, and should probably best be left to expert. Again, this is just my $.02 and is based on my personal experience with this issue. Good Luck. J L |
Cliff, quit screwing around with your mixture already. Didn't you tell me you had a shop dial it in for you? Replace the accumulator and filter. I'll even make you a deal. I have a brand new accum and filter that you can swap in. If they fix the problem, buy them from me. If not, I'll take them back. You can't lose! Call me on my cell.
Yeah, Cliff, what Chris said!! That way you won't steal my parts!!
this thing is making me mental.
i agree, mixture is best done by someone with the tools. i took my car to a mechanic, and he helped me check everything. freq valve, aav.... my mix was lean, and my timing was off. believe me, it runs tons better. but again, when the car is parked steeping in it's heat, (approx 45 mins) when it starts, it starts immediately., but chugs along. i got voltage at the WUR, but when i took it off to take a look i noticed someone in the past had dropped it. there is a dent at one of the screw heads. and i only have 9ohms at the connection. can a WUR be bad, when the pressures are decent? and any experience with rebuilt WUR's. still trouble shooting, but wondering, just in case. thank guys cliff. p.s. due to my extended vacation, i estimated the fuel to be 6-7 weeks old, so i took it out and added fresh stuff, from chevron. |
I think it is your accumulator. 22 psi is too low. The pressure should stay close to your warm control pressure for about 20 minutes. Probst says 3 bar for 20 minutes(44 psi). I know my old Mercedes would hold 40 psi forever. Good Luck.
mitchell, i checked and me and chris have different part numbers on the accumulator. i would have.
Intake leak! If your control pressures check out, then you're running lean because of a leak. It runs better cold because it's overly rich when cold.
thanks stoney. and everyone else. back at it this morning. I SHALL PREVAIL!
Just fixed a similar problem.... chased all the miscellaneous things, did all the CIS pressure test and it ended up being damn air leak in the big boot on the top of the throttle body. Those damn vacuum leaks with kill you. Anyway, problem fixed now and happy motoring.
Good luck...I understand your frustration. Chris |
Popping through intake to lean. Popping through exhaust to rich
1981SC |
Cliff-
You need any help? Sitting here looking at the rain and trying to figure out ways to procrastinate on painting a bathroom and hallway. I am sooooo sick of f---ing house projects!!! PM me if you want to stop by. -Jon |
Vash (or is it Cliff?),
The next time you have the problem, remove the air filter, reach in and raise the air flow sensor plate breifly, like 3-4 seconds. You should hear a sort of whine from the injectors spraying. Not too long or you can flood the engine. Then crank the engine and see if the problem has improved. Sounds to me like bubbles in the gas in the injector lines could be the problem. Worth a shot, and it's cheap. Your residual pressures seem to be in spec, but this might not tell the whole story. |
Yelcab1, I think what was meant is that if it is running very lean and you pull the cap, it could cause the engine to stop running due to extremely lean condition. The extra air would prolly push it over the edge.
Obviously if it is adjusted to spec it will continue to run but will stumble a bit. If it is idling too rich, opening the cap and allowing in un-metered air might actually help the idle a bit. |
ok, i am effen taking a break.
car runs fine, but still upon startup warm, after sitting for a bit, the idle will stumble around @ 500 rpm. schit doesnt happen when there is a mechanic around. adjusted timing, mix. WUR ohms went huge warm, (thinking about this some more, it shouldnt matter, car is hot anyways), and big dent in it, made me change it out. new acumulator, and since i was there, new filter. fresh gas. found crack vacumn line to WUR and replaced it. had a new oil cap gasket around, so i put it in. freq valve checked. looked for vacumn leaks at injectors, none. *****, the list goes on. gonna flashlight the AAV manana. showered, garaged closed, i am gonna eat out, drink some and hang with the girlfriend. i think she understands CIS now, i talk about it so much. cliff |
scott, i think high idle is easier than low idle. good luck
edit: AAV is AAVing perfectly. NEXT! |
Cliff,
Did you ever try my suggestion to briefly lift up on the air flow sensor before you try the start, in a situation where you think you are going to have the warm start problem? |
| All times are GMT -8. The time now is 07:13 PM. |
