Detached Member
I've only got 15k on the engine since I bought the car. I've changed the oil every 5k and adjusted the valves once about 10k ago. I don't have a maintenence schedule for the car, but oil every 5k and valve adjust every 15k is what I'm gathering from the Board. I don't track the car. Any contrary views? What about the trannie oil? How often do you change it. Distributor felt once a year seem right to me. Spark plugs, rotor and cap?
Hugh |
Make Bruins Great Again
There are a lot of differing opinions on "how often..." Keep in mind that street versus track makes a difference. For street driving, my garage queen gets:
Oil: 5K Valve adjust, plugs, cap, rotor: 10-12K Trans: 2 yrs Brakes: 2yrs
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
I'm a 6K per annum driver in mine and I am just about the same as Joe on all counts...
84 3.2 'euro' 911 Carrera Sport (Stock) |
I do about 5k a year. Oil change once a year. While I'm in there, I do the valves. Because it's fun!
I would think that cap and rotor are probably good for more than 10-12K.
John F. Lewis 74' 911S Targa + 930/02 76' 914 - Eternal Type IV project FOR SALE |
You are doing it all wrong...track the car!
For me tranny fluid every 2 years or 25K. Lube the dist shaft according to Warren every oil change. Remove the dist every 3-5 years and inspect and possibly get rebuilt, Warren's suggestion again. Valves on the early cars every 10K; later cars about every 15K.
An italian tune-up at least once a week.
68 911L |
I think that an "Italian tune-up" is when you drive the car at high rpm to keep carbon deposits from building up.
"But officer, I was just keeping the valves on my car clean!"
'08 RX350 (Hers) '84 911 Carrera '83 911SC Cabrio '06 Miata |
Detached Member
Adjust rear view mirror,
Check for cops front, rear and side-to-side, Take it to redline in as many gears as possible, Repeat as necessary.
Hugh |
search up the long term maintenance thread
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
For what it's worth the owners manual that came with my 86 carrera 3.2 indicates a 15K maintenance interval for virtually everything: oil & filter, valves, check trans fluid level, check adj of clutch, brakes, wheel bearings & everything else or at least annually, and every 60K for plugs,check belts, change transmission fluid, change O2 sensor or every other year - under "normal" driving.
Not sure exactly what "normal driving" is but there is also a disclaimer of "If you use your car under severe driving conditions, it may be necessary to change engine oil more frequently than prescribed in the maintenance schedule."
1986 Carrera Coupe 1999 Chevy Tahoe 1987 Chevy Blazer 1955 Chevy Apache 3100 Pickup "A little knowledge is a dangerous thing" |
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Recreational User
Is it necessary to replace the distributor felt cap? Never heard that one before. Its not even listed as a part. I thought you just put a few drops of oil on it.
John C 1988 911 Carrera coupe 2002 BMW 530 Last edited by Decolliber; 04-20-2005 at 06:58 PM.. |
Recreational User
For the 3.2 Carrera, transmission fluid, fuel filter and O2 sensor every 60,000 miles per the Warranty and Maintenance booklet. Spark plugs every 2 years or 30k miles, air filter and belt check every 30k miles, and everything else every 15k miles.
Track use, frequent short trips and dusty conditions will shorten the maintenance intervals. |
Detached Member
Thanks all
I don't have an owner's service manual and was curious.
Hugh |
I'm gonna have to get that 101 projects book, aren't I? I have no idea how to do a valve adjust. And I bet my car needs it. hehehe
Matt J. 69 911T Targa - "Stinky" 2001 Boxster "Stahlgewehr" |
