RC-Escape's Avatar
Car Lifting Question?
I'm going to have my fuchs refinished this week and obviously I need to remove the four wheels from the car (duh). Here's my concern - I have never had the car up on 4 stands at one time.
What's a safe method - Do I get the front two wheels up on stands first, or the rear wheels first? Does it matter?
Do I jack one wheel up at a time and place one stand under the car at a time?
I know this should be a simple procedure, but I'd feel safer with some advice. Thanks for your responses in advance!
PS - I did a serach on this BBS, but no luck.
Rick
Bay Area, California
1984 911 Carrera Targa
1973 VW Beetle
Old 04-25-2005, 12:14 PM
randywebb's Avatar
search on jack jacking stands - that will bring up a lot of things
any of the ways you state are ok if you chock
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 04-25-2005, 12:18 PM
Longhoods Unite!
PhatRedHead's Avatar
Send a message via AIM to PhatRedHead Send a message via Yahoo to PhatRedHead
i lift the back of my car by the center seam of the motor, i can two jack stands under the torsion bar tube at the same time, pretty simple and a one man job.
once you got that, just go slow and you should be fine to do the front. for me, i put jack stands on the front mounts of the A arms, gives it a longer base than what the wheels are and just be slow and methodical about it and you should be ok, just no jumping in and out of the car, no pretending you are a rally driver while up on stands.
hope that helps
Joe
1970 911T -- Neglected, oil burning problem, batman smoke
1974 914 2.0 Weber'd -- new project!!
**My Wife and I bought our first house in August of 2009, the footprint of the house is just over 1100 sq. ft...my garage is just over 1000 sq. ft. We compromise well **
Old 04-25-2005, 12:20 PM
Bill Verburg's Avatar
Jack up one side, place stands w/ wood blocks,
then ditto the other side
Bill Verburg
Old 04-25-2005, 02:35 PM
Registered abUser
TerryH's Avatar
break the lug nuts loose before putting it up. safer and easier....
'81 911SC Coupe SOLD
Old 04-25-2005, 02:41 PM
Unless you have an impact gun
Bill Verburg
Old 04-25-2005, 02:49 PM
safe's Avatar
I always feels safer jacking up the rear first. Then the whole cars pivots safely on the rear torsionbars when jacking up in front.
Since you jack up the front by the torsionbar mounting, you will lift only one corner if the rear is not on stands.
Magnus
Old 04-25-2005, 03:24 PM
Registered abUser
TerryH's Avatar
Yeah, I was going to add that disclaimer, I swear. But with the price of fuch lug nuts, does anyone use an impact gun on them?
Old 04-25-2005, 03:35 PM
RC-Escape's Avatar
Thanks for your responses. I did a search using "jack, jacking stands" and found a lot of information, and a lot of disagreement. Seems there are two camps; first one for using the jack pads and doing one side at a time, and the econd one for jacking up the rear of the car under the engine and using two jack stands under the rear torsion bars. And then doing the front.
Well, the instructions for the rear lift are cystal clear, I'm just not sure about lifting the front - I know where to place the jack stands in the front, but still not quite sure where to place the jack to lift the front?
Rick
1973 VW Beetle
Old 04-25-2005, 03:57 PM
safe's Avatar
You can only place a jack on the torsion bar mount in the front, there is no "center point", unless you use a 2x4 or something to spread the weight. Therefore place the rear on stands first so the car is stable.
I usually jack the front by the rear mount in the front, but I have a long jack.
Magnus
Old 04-26-2005, 01:24 AM
