| Registered Join Date: Jul 2003 Location: Back in B'ham, AL
				930 Thermostat Lines
			Looking at the external thermostat and the oil lines going to the front cooler, which one is the supply line to the front cooler - top or bottom?
|  04-25-2005, 01:03 PM |
| Moderator |
			Top of the head answer  -  bottom is feed top is return. easily checked though, which one warms to the touch first?
				__________________ Bill Verburg '76 Carrera 3.6RS(nee C3/hotrod), '95 993RS/CS(clone) | Pelican Home |Rennlist Wheels |Rennlist Brakes | | ||
|  04-25-2005, 01:25 PM |
			I understand, but unfortunately the hoses are diconnected because I'm installing a front valance oil cooler in series with the 28 brass. I believe that I should feed the valance cooler from the top to let the oil flow down through it instead of up - less friction... I can go either way though, and really believe it is not a big difference. Thanks anyway.
|  04-25-2005, 01:44 PM |
| Moderator |
			In a pump pressurized system the direction of flow is, for all practical purposes, irrelevant.
|  04-25-2005, 01:47 PM |
			We concur Bill. Thanks.
|  04-26-2005, 03:22 AM |
