I've just replaced the CV joints on one side ,very messy-great fun.When I started on the other side I found spacer/washer thingies that were sitting between the inboard side of the CV joint and the shoulder of the axle ( the side of the joints away from the ends of the axles ).These were not present on the other axle. So now I am confused, do I throw them away or put similar ones on the side already done ?.
1957 KR 200 Messerschmitt Bubble Car 3 wheeler-my first rear engined air cooled German car,alas long gone!. 1977 911S 2.7 to spend money on 2006 Tundra for acting grownup |
What car?
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Ooops sorry,
1977 911S 2.7
sounds like the previous wrench either lost it or couldn't fit the circlip on with the washer. It is a tight circlip fit. I don't know if damage happens without it ?
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Earlier cars like yours have the washers. The SC and Carrera don't call for washers at all. But, it would not kill you to put them on. Schorr washers, I think they call it. Some go as far as drilling and wiring the bolts, and replacing with all new bolts.
I, well, just use some red loctite on old bolts. I even re-use flywheel bolts on SC and Carrera with no ill effects. But, that's just me.
Thanks Guys but maybe my explanation wasn't clear.The thingy in question is a large washer that fits over the axle itself and sits up against the shoulder on the shaft as if it was to prevent the CV joint riding over the hump and sliding in towards the middle of the shaft ?
Okey dokey, Thanks Ronin
