Me like track days
Craig 930 RS's Avatar
Question ~ Victoracer vs. Toyo RA/1....which to order today? ~
Victoracer (NOT V700 Victo)....vs. Toyo RA/1
I've run Yokohama A032Rs for 6+ years now - time to step it up a bit.
Parameters:
2.5 deg neg camber front, almost 3.0 rear.
Some street driving
Lots of track use
Tire must be dual-purpose, for now
225/245 or 265
Cost is fairly close, so this isn't a deciding point.
I've done the searches, read the reviews, & have friends who use both on their cars.
Now its time to choose. Fire away!
TIA,
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 03-31-2005, 10:13 AM
Administrator
Jack Olsen's Avatar
Toyos.
Old 03-31-2005, 10:32 AM
ted ted is online now
likes to left foot brake.
ted's Avatar
Toyos
Old 03-31-2005, 10:39 AM
Vintage911Racer's Avatar
Send a message via AIM to Vintage911Racer
Toyos, shaved
Mark Scott
Vintage 911 Racer
1967 911S 2.4L ROCKET
Powered by Faragallah!
www.scottassociatesracing.com
Old 03-31-2005, 10:44 AM
Me like track days
When I did my search for 'Proxes RA/1' I came across a post by Jack from 2001 where you ran RA/1s.
What were your impressions, Jack?
Craig, I run them all the time. I like them. About the same as the Kumhos, but last longer and dont go away as fast.
Mark Scott
Vintage 911 Racer
Old 03-31-2005, 10:46 AM
Me like track days
Mark -
Are they a 'must-shave' tire for you?
I am running about 2.5 camber front & 2.9 rear. OK for an RA/1?
Old 03-31-2005, 10:53 AM
They are a must shave for me. Otherwise the tread blocks have too much side to side wobble. Once they wear down a bit they are OK. But if you are looking to go fast right out of the box, you must shave them.
I am running -2 in the front and -2.5 in the rear... THat seems fine, I feel like the tires could take more -negative camber then what my car will give me.
Mark Scott
Vintage 911 Racer
Old 03-31-2005, 10:59 AM
Me like track days
Excellent! The I will go ahead and order the RA1s.
Thanks a ton,
Old 03-31-2005, 11:09 AM
Maybe its too late... but I'm going against the flow.
I much prefer the Kuhmos - better stick & more predictable for me.
But, if you use it for street driving, they are useless in rain after a few track days... assuming you don't shave the Toyos (but that means they will be VERY squimmy & 0 stick).
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
Old 03-31-2005, 11:27 AM
Me like track days
Got 'em. Wnat great service? THese guys are the best:
Todd
Frisby Performance Tire
www.frisbyracetire.com
1.800.798.7201
Old 03-31-2005, 11:48 AM
Me like track days
225/245 16s for $162.95 and $169.95 - bought 3 of each tire.
These guys are enthusiasts and I'd also highly recommend them from a CS standpoint.
Old 03-31-2005, 11:54 AM
Crash94536's Avatar
I've tried both and I prefer the Kuhmo Victoracer.
I have the luxory of two sets of tires and rims. For the track events I put the Victoracers on the roof rack and change them once I arrive at the track.
I would not use Victoracers for street driving, they wear out too fast. But on the track they stick really well after they warm up.
A couple of my friends use the Toyos for both track and street. One of them has tried S03s and liked both but preferred the Toyos. Both of them feel the Toyo is a good balance for track and street use.
On one of our track events I was riding with one of my friends in his 300ZXTT, halfway through the session we felt a "vibration" from the right front wheel. We pulled into the pit and were shocked at what we saw; there was a band about three inches wide all around the outside portion of the tire where the casing was exposed! We both looked at the tires prior to going out, we knew this would be the last trip to the track with that set of tires. We were also very surprized it was still holding air! Like me, he has two sets of tires and rims and uses Victoracers for track sessions.
I have a good shot of myself going around turn six, reverse direction at Thunderhill that I will post soon.
We are doing another driving event on June 28th at Thunderhill in northern Calif., let me know if any of you are interested. We could use more P-cars!
Old 03-31-2005, 12:08 PM
don911's Avatar
Craig,
You're too quick. I have a set of RA1s mounted on 8s and 9s sitting in the garage that I was going to let you use for a test drive. They have one track day on them.
I went from A032s to these as well. I think you'll like the RA1s, shaved or not.
Don
24 Cayman GTS - GT Silver
23 Cayman GTS - Arctic Grey - Sold
97 993 Coupe - Arctic/Black - Sold
13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue
Old 03-31-2005, 12:16 PM
Me like track days
So Crash, then those were the RA/1s that had (what appears by your description) the tread blocks ripped off?
Don - ah yes, I remember you had them now - saw them on your car at my house. How would you compare them to the A032Rs? I've used them for *6* years now -
Old 03-31-2005, 01:57 PM
Crash94536's Avatar
Hi Craig,
the Victoracers were the tires that lost the tread blocks, his other set of rims had the Toyos.
Crash
Old 03-31-2005, 03:35 PM
Me like track days
http://forums.pelicanparts.com/porsche-911-technical-forum/218766-toyo-ra-1s-track-report-post1887336.html#post1887336
Old 04-28-2005, 01:54 PM
