Heater backdate and AC on an SC?
I've looked at previous posts on backdating the heater, and everyone seems to ditch their ac. Is it possible to do the heater backdate and retain the ac on an sc?
Also, my car has the automatic temperature control for the heat. Will that complicate the backdate, or is it just the ductwork I'm changing?
Thanks!
Tom
1978 911sc Targa (Sold )
2005 BMW X5 3.0i
2000 BMW 528iT (5 spd, sport)
2000 BMW 323Ci conv. (4 sale)
1987 Corvette Callaway Twin-Turbo Conv
Old 04-28-2005, 09:40 AM
Who is John Galt?
Rondinone's Avatar
I run my automatic heater without the engine compartment fan connected, and it works fine.
'79 911sc Targa
'02 slk230 kompressor
'84 Tamiya Falcon
A democracy cannot exist as a permanent form of government. It can only exist until the voters discover that they can vote themselves largesse from the public treasury. From that moment on, the majority always votes for the candidates promising the most benefits from the public treasury with the result that a democracy always collapses over loose fiscal policy, always followed by a dictatorship. The average age of the world's greatest civilizations has been 200 years.
Old 04-28-2005, 10:05 AM
Go Speedracer, go!
SpeedracerIndy's Avatar
I have automatic heat with backdated heating. It does not interfere with the auto heat.
1981 SC ROW Coupe
Old 04-28-2005, 10:23 AM
ianc's Avatar
You're in Seattle? Shouldn't you be ditching the AC and keeping the stock heat then?
ianc
BMW 135i. Nice. Fast. But no 911...
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
Old 04-28-2005, 03:29 PM
Senior Member
Superman's Avatar
I'm in Seattle. In the summer I take shorts to work and change in my office before heading home. it's a good life.
Mocha 1978 911SC. "Coco"
Old 04-28-2005, 03:46 PM
Ah, but for those trips to Western WA "wine country"! I know, it's a Targa, too. I may end up pulling out the ac, but for some reason I feel like I'm losing something - versus all the other backdates where you gain things like HP, etc.
2005 BMW X5 3.0i
Old 04-28-2005, 03:56 PM
rfuerst911sc's Avatar
I have a 83SC with backdated heat and kept the AC and no problems.My situation I only really need heat maybe 2 weeks out of the year and the AC about 40 weeks!!
Old 04-28-2005, 03:57 PM
ianc's Avatar
Backdating the heat doesn't really gain you anything either, except heat that doesn't work as well...
ianc
Old 04-28-2005, 04:19 PM
I was looking for a little less engine compartment mess and an easier SSI installation. It doesn't get all that cold or hot here in Seattle; so, marginal heat and marginal ac (stock) do ok.
2005 BMW X5 3.0i
Old 04-28-2005, 04:32 PM
ianc's Avatar
If you backdate, the heat will probably work almost as well when you're cruising, but it doesn't work worth crap at idle. If you spend some time in Seattle (like I definitely do in CA) sitting in traffic jams in the rain, you'll wish you had kept the fan...
ianc
Old 04-28-2005, 04:41 PM
The key to backdating the heat is to install footwell blowers and all the wye connectors for the duct work. I this was my winter project and it works very well. The wye connector allow you to use the side dash vents to blow some hot air on the door glass and vent windows. One of the nice things about the install is that I can now warm up the interior while the car is idling.
Peace, Ron
www.ronorlando.net
78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk
Own a gun and you can rob a bank , own a bank and you can rob the world.
Old 04-29-2005, 08:04 AM
Ron,
Is there a "write-up" on this somewhere? A search gets me more "hits" than info. Particularly interested in footwell blowers and "wye" connectors information and installation "how-to".
Thanks,
Jerry M
'78 SC
Old 04-29-2005, 08:16 AM
Jerry..Search on mysterytrain or footwell blowers. Unfortunately, I don't think I got to post much on the install. On my 78 targa, behind the footwell carpet there was an opening that allowed the alum/paper duct to snake up into the trunk area. My advice is to buy some duct work before you start the project because a soon as you touch that 30 yr old stuff it is going to come apart. Anyway, the cavity is deep but the opening was a bit tight and I wanted the blowers to be set into the cavity as far as possible to I could keep the stock carpet and look. The carrera's had a big old removal carpeted panel. ok, I found the links for you.
electrical question (footwell blowers)
Footwell blowers in a 78SC
Peace, Ron
www.ronorlando.net
Old 04-29-2005, 08:48 AM
Not as it seems
juanbenae's Avatar
sup, you should not tease the ladies around the office that way.
Old 04-29-2005, 08:53 AM
Not as it seems
juanbenae's Avatar
ianc
my heat worked better post backdate, although my fan was broken.
Old 04-29-2005, 08:55 AM
Senior Member
Superman's Avatar
You apprently have not seen my legs.
Old 04-29-2005, 09:02 AM
Designer King
Paulporsche's Avatar
Shouldn't you be wearing tights?
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 04-29-2005, 09:40 AM
ianc's Avatar
Yeah. The fan would make a difference.
ianc
Old 04-29-2005, 10:31 AM
Virginia Rocks!
VaSteve's Avatar
Re: Heater backdate and AC on an SC?
Yes, I did this over the winter and I had no problem. I can take a photo if need be.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 04-29-2005, 12:10 PM
Thanks Ron. Very helpful. Now to take a look behind that carpeting.
Jerry M
'78 SC
Old 04-29-2005, 06:18 PM
