B D B D is offline
B D's Avatar
Removing Side deco trim
How do you remove the side deco trim on an early 911 ('68 SWB), how is it attached? Any tips and tricks?
68 911L
Old 04-29-2005, 11:26 AM
Yellowbird RS's Avatar
X/A
Old 04-29-2005, 11:51 AM
B D B D is offline
B D's Avatar
Thanks but that's for a later car. This is just a metal strip with a rubber insert.
68 911L
Old 04-29-2005, 11:55 AM
abit off center
cgarr's Avatar
pull out the rubber insert out and there are screws behind it, then I can tell you how to get the rubber back on.
Craig
______________________
Craig
G2Performance
Old 04-29-2005, 12:04 PM
randywebb's Avatar
While waiting...
Go buy some detergent, some silicone spray and a good pair of quality 90o needle nose pliers....
It's gonna be a mutha to get back in.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 04-29-2005, 12:10 PM
B D B D is offline
B D's Avatar
Any tips for pulling out the rubber without damaging it? I am going to give it a try this afternoon. I am thinking warm water would help or leaving out in the sun.
I am thinking of removing the side trim, from bumperettes (I'll have to see what's behind them) and installing a mesh grill under the lid.
68 911L
Old 04-29-2005, 12:14 PM
B D B D is offline
B D's Avatar
Thanks Randy and Craig!
I am thinking there has to be a trick to this, how did the factory do it? The metal part had to be screwed in first and the rubber next. I am going to look in my parts catalog when I get home, maybe I could just remove the some of the trim where the screws are.
68 911L
Old 04-29-2005, 12:19 PM
abit off center
cgarr's Avatar
I guess if its a real old rubber it may not pull out very well without breaking? and would be real hard to put back in too, I worked with a new rubber on mine and used a screwdriver to push the rubber back into the slot but then it was rather soft too.
Craig
Craig
G2Performance
Old 04-29-2005, 01:28 PM
B D B D is offline
B D's Avatar
Nevermind there a seven screws total. I am going to check with my paint and body guy about the cost to fill and respray the holes first.
68 911L
Old 04-29-2005, 01:58 PM
