84CAB's Avatar
Fiberglass Heat Backdate
Received the fiberglass heater duct from Thom today. The part is well constructed and fits nicely with no mods. For proper sealing I did cut the rubber boot that fits around the heat exchanger where it passes through the engine tin. Will try to source the flexible tubing locally tomorrow.
ELVIS 84 CAB -SOLD
Old 04-28-2005, 02:39 PM
1. Who did you purchase the part from, Thom who? Need his e-mail/ contact information.
2. I thought the only way to backdate was buying old parts, how much did this fabricated part cost you?
3. How much did you remove to get it in?
4. Did you have to remove the fan and alternator?
Old 04-29-2005, 01:16 AM
Glasgow 911SC's Avatar
Thom "widebody911" Fitzpatrick.
Chris
1982 911 SC Hellblau Metalic
1997 Boxster 986 2.5l
Old 04-29-2005, 03:57 AM
rcm rcm is offline
rcm's Avatar
I also purchased from Thom. The part fits good. It's the easiest way without trying to find ols parts that have to be retro'ed. He does nice work and ships quick.
Rick
" too many people spend money they haven't earned to buy things they don't want to impress people they don't like" Will Smith
Old 04-29-2005, 04:00 AM
84CAB's Avatar
Thom is aka widebody911. It took about 30 minutes to install. It requires removal of the existing heater blower assembly and the distributer cap. I have the stock heat exchangers so I only had to use the passenger side duct. I believe Thom is working on the duct for the other side. Check out rennlight.com
ELVIS 84 CAB -SOLD
Old 04-29-2005, 04:04 AM
greglepore's Avatar
Curious what hose you guys are using - scat, or something cheap from an autoparts place?
Greg Lepore
85 Targa
05 ST3s (unfinished business)
Old 04-29-2005, 05:00 AM
84CAB's Avatar
SCAT and SKEET are two I've seen used by other people. I am looking locally for something that will work.
ELVIS 84 CAB -SOLD
Old 04-29-2005, 05:13 AM
...and for those who may want their existing ,metal duct modified you have John Walker as an option. Very nice work as well.
Pics from V9FF and Piedogger.
Save money with Heater backdate from JW
Warren & Ron, may you rest in Peace.
Old 04-29-2005, 05:31 AM
another pic
Old 04-29-2005, 05:32 AM
Looks great. I thought there were also some wiring changes that needed to be made. From threads on this before I saw someone tried a resistor mounted on the engine. Soooo did you have to make any wiring chages or just tape off the wires to the blower motor?
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not.
2012 BMW 528i (wife's)
2007 Toyota FJ (rain and off road days)
Old 04-29-2005, 06:14 AM
My wife likes heat to, I'll look into heating both sides.
My blower motor is gone along with all of my hoses, the shop said they were shot - I asked for them back just for reference so I could order replacements. The shop contrary to Michigan law did not give me my parts back - never going back there.
Must I do everything myself.
Old 04-29-2005, 07:01 AM
84CAB's Avatar
Heat works on both sides using the one duct if you have the factory heat exchangers.
ELVIS 84 CAB -SOLD
Old 04-29-2005, 08:10 AM
Go Speedracer, go!
SpeedracerIndy's Avatar
Not on pre-1984. On the Carrera there is a crossover pipe that runs under the engine compartment that joins the two sides. On a pre-Carrera, this crossover pipe isn't there, creating two independant heat paths. At least that's how my SC is.
1981 SC ROW Coupe
Old 04-29-2005, 08:15 AM
If you already have or can get your mitts on a set of OEM ducts, having John Walker mod them is the way to go; otherwise my fiberglass repro is an option. If you're weight-concious, the fiberglass part wins hands-down
When I get better at doing the layup and trimming I'll make them in carbon fiber, too.
I'm very close to selling the right-side piece. Here's a prototype piece I pulled a couple days ago. It's ugly because it didn't get gelcoated and I only rough-trimmed it with tin snips.
Old 04-29-2005, 09:16 AM
jdowty3's Avatar
My SC has no cross-over tube either. I'm just waiting for Thom to finish the right side piece to do the backdate. I had planned to leave the blower and hoses off when I put my motor back in last week but realized with the volitile Michigan weather, I may need some warm air to clear the windows.
Jim Dowty
97 911 Coupe (Forest Green metalic, sunroof, leather)
PCA RSR region Insurance chair and Board member
Gruppe B #309
Old 04-29-2005, 10:42 AM
efhughes3's Avatar
Yet another reason to buy a Carrera in lieu of an SC
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 04-29-2005, 11:12 AM
84CAB's Avatar
If you want to keep the footwell blowers you have to do some creative wiring. Otherwise just tape it off.
ELVIS 84 CAB -SOLD
Old 04-29-2005, 11:18 AM
Go Speedracer, go!
yet another reason a Carrera weighs more than an SC.
1981 SC ROW Coupe
Old 04-29-2005, 01:01 PM
Without the rear blower and footwell blowers how much heat do you get? The footwell blowers haven't been working for several years so th eonly heat I get is controlled by the two center leavers. Luckily that's enough for Houston "winters" even without the top on the car. But without the rear blower do I get any heat with the center levers or do I need the footwell blowers?
Elvis what kin of creative wiring are you referring to?
Old 04-29-2005, 01:25 PM
84CAB's Avatar
The creative wiring is the resistor mentioned earlier. According to others the backdated heating works better than heating with the blowers - in all cases except at idle. I don't know... My footwell blowers have never worked so I'll try the set-up using passive air heating. After next winter well see, I might have to go back to the original set-up. You guys will know the results if you see a used fiberglass duct for sale in the PP Classifieds.
ELVIS 84 CAB -SOLD
Old 04-29-2005, 03:18 PM
